Sway bar in a 1950 Ford with 8.8" Explorer Rear End
How should the sway bar be mounted to the truck frame? This is hard to explain. I have the rear end in and would like to use the Explorer Sway bar it is installed on the rear end and paid for. Is there an angle that should be maintained or is better? Such as pointing the arms that attach to the sway bar at a 90°angle to the sway bar? Should the arms point towards the rearend? Towards the front? I don't have a clue so anything would be helpful.
Hi Christopher2,
I'm in the process of doing the exact same thing in my '53 so maybe I can help. My situation is a little different because my truck is bagged and I need to make sure I have sway bar clearance if I'm all the way up or all the way down. I'm setting mine up so that the "dip" in the center of the sway bar is 90 degrees to the ground at ride height. It puts the "arms" at a funny angle, but it's the same way it's positioned in the Explorer so I'm assuming that it will be right in our trucks too.
I hope I helped - Brad
Chris the bars go to the rear. I have some pics of my install in my gallery. I did a little mod to the mount links (shortened) then brought them up inside the frame where I boxed mount points, had to bend the sway bar slightly to go inside the frame. And yes the bar should stick out at a 90 from the diff.
Mike
Mike
How did you shorten them? Cut them with a chop saw and weld back together? I am going to have to look at mine tonight might have to chop them also or aim them towards the rear allot. I think aiming them to much to the rear would defeat the purpose.
Mike
Mike
hurst1979olds
08-08-2017 12:13 AM
Imports2Domestics
13
09-07-2013 10:09 AM
