Question about boost pressure.
Old Oct 14, 2008 | 07:11 PM
allis327's Avatar
allis327
I just finished my gauge install today (Dipricol Optix) and was wondering if 17 psi @ wot is ballpark. I plan on installing new boots when I do my foil delete and paint my pipes. Just wondering how far off i maybe and if I need to do the boots sooner. I had alot better fuel mileage before the guages but i usually don't speed everywhere to see if my gauges work. thanks
Old Oct 14, 2008 | 07:14 PM
zx250's Avatar
zx250
Of the next Riffraff East
Without a tuner, that's about right. Could be a tad higher so check the boots.
Old Oct 14, 2008 | 07:59 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Thats not bad without a tuner/chip. Keep doing what you are doing. Take it one step at a time. Keep adding mods, and you will hit more boost.
You think you don't have MPG right now. When you get the DP, you will not be able to help yourself.
Old Oct 14, 2008 | 08:04 PM
DieselCamper01's Avatar
DieselCamper01
About the best I have seen is 15-16 but I also still have stock exhaust. Looks normal
Old Oct 14, 2008 | 08:20 PM
superduty4x4's Avatar
superduty4x4
I have an early turd (smaller turbo), 6637 intake and 4" turbo back duals and can hit 22 PSI WOT empty. Towing I've hit up to 28 pulling a grade. Maybe it's my small, puny early turd turbo but I seem to be the exception rather than the rule.
Old Oct 14, 2008 | 09:13 PM
GEugeneS's Avatar
GEugeneS
I can only occassionly hit 15 lbs WOT but I got the Edge Evo and that I am told isn't a real gauge.
Old Oct 14, 2008 | 09:32 PM
That_Guy's Avatar
That_Guy
Gary, I hope your getting that reading just because the gauge is a POS, its either that or your leaking somewhere..
Old Oct 14, 2008 | 09:38 PM
ts_stroker's Avatar
ts_stroker
stock my truck hits right around 20 wot but thats also in 4th gear...lil easier for me to hit it then an auto can..
Old Oct 14, 2008 | 11:27 PM
Izzy351's Avatar
Izzy351
I get about 18-19 max with the red line unplugged in stock. I wouldn't worry about 17. Once you get tunes and start hitting 26-28, you'll know you're okay.
Old Oct 15, 2008 | 12:05 AM
Pocket's Avatar
Pocket
Bone stock I only saw a max 18 psi, so 17 is right in the normal range.
