Tranny temp sensor
Old Oct 14, 2008 | 05:28 PM
Joe_D's Avatar
Joe_D
Tranny temp sensor
When I got my truck the tranny temp sensor was mounted in the line going to the tranny cooler right after it comes out of the transmission. Is that a good spot or would it be better to move it to the plug on the drivers side?
Old Oct 14, 2008 | 06:13 PM
tjbeggs's Avatar
tjbeggs
That spot is just fine. It will show the hottest temps of the fluid compared to the other spots. The test port will be the coolest and the TFT sensor via scan tool will be in the middle
Old Oct 14, 2008 | 06:45 PM
Joe_D's Avatar
Joe_D
Good to know. If it ain't broke...
Old Oct 14, 2008 | 06:57 PM
oldbird1965's Avatar
oldbird1965
Joe_D, I've got one in both. The gauges show 20 to 30 degrees different with the sensor where you have one the hotter.
Old Oct 15, 2008 | 04:31 PM
Welk49's Avatar
Welk49
i have mine in the port on the DS.* It bottoms the gauge out at 260 after a little bit of driving.* I have checked the fluid with a infared gauge and it's running at 170* I have tried a couple of senders and same thing.* Even got another gauge same thing.* A local shop said I should put it in the pan but people here say not to a little confused because where I have it is where everyone says to put it.
Old Oct 15, 2008 | 06:08 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You have it in the right place. There's something wrong with the sender, gauge, or wiring.
Old Oct 15, 2008 | 09:47 PM
Welk49's Avatar
Welk49
that's what I thought. I need to check the wiring then because I have went through 3 diff. senders and 2 gauges now.
Old Oct 15, 2008 | 10:43 PM
RubberDuck's Avatar
RubberDuck
NO Mark your wrong!!!! Just kidding, your totally right like always. I didn't even know there was another place to put one.
Old Oct 16, 2008 | 08:14 AM
TexasDiesel97's Avatar
TexasDiesel97
Welk49, if your using an electric gauge, you need to make sure you have a good ground. Had the same problem with my autometer gauges, hooked my ground in to the one for the cig lighter, works fine now.
Old Oct 16, 2008 | 08:57 AM
BlueMule's Avatar
BlueMule
You didn't wrap the sending unit with teflon tape did you? That could cause you gauge to act up because of not having a good ground.
Old Oct 16, 2008 | 01:16 PM
Welk49's Avatar
Welk49
had a break in the wiring got it fixed now and working fine thanks
Old Oct 16, 2008 | 04:21 PM
GWF3507.3's Avatar
GWF3507.3
My temp sensor is tapped into the fwd portion of the pan. It seems to get way above 170 even in the cooler wx we have been having. During summer with high near 100F guage indicated 230F(running empty) which is almost redline on my BullyDog guage. I have the stock cooler which is weak but am wondering if this location on the pan is triggering higher than normal temp readings. Any advice or comments please.
Old Oct 16, 2008 | 05:46 PM
tjbeggs's Avatar
tjbeggs
Either your gauge is wrong or running too hot! Check the pan temp with a thermometer to check the gauge and install a better cooler.
Old Oct 16, 2008 | 05:52 PM
GWF3507.3's Avatar
GWF3507.3
What kind of thermometer? Would a meat thermometer work?
Old Oct 16, 2008 | 06:03 PM
tjbeggs's Avatar
tjbeggs
an infared point and shoot type would be best but if you can get good contact with the pan surface the meat thermometer might work. Just don't tell your wife!
