Sponsored by: Real Truck
03 5.4 Y pipe
Old Oct 13, 2008 | 10:31 PM
85F_150driver's Avatar
85F_150driver
03 5.4 Y pipe
I reciently purchaced a 03 Super Duty equipted with the 5.4 auto 3.73 set up and I was wondering if anyone has simply removed the restricors and left it in the factory style T pipe? I was thinking about trying it as a quick fix but if it wont make any difference then i will make a Y pipe. So far I have removed the cat, replaced stock muffler with a turbo, and put a true flow filter in it. Any other suggestions for better mileage would be greeatly appreciated. Thanks, Ben
Old Oct 14, 2008 | 02:54 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Never heard of anyone going to the bother of removing the necked-down portion and not changing the right-angle "T".
Old Oct 14, 2008 | 04:43 PM
ReAX's Avatar
ReAX
And I haven't found a bolt on y-pipe for the 5.4L. If you try it, I'd love to know how it works. It's one of the mods I'd like to try myself, but I am not so good at welding.
Old Oct 14, 2008 | 05:47 PM
dkf's Avatar
dkf
The Ebay y-pipe will work on the 5.4l and 6.8l however it isn't a bolt on. Cut and weld on.
You want exhaust to transition as smoothly as possible so a "T" is not good. Since you have the 5.4l you don't have to worry about flutter which the stock ypipe was designed to eliminate on the 6.8l only.
Old Oct 14, 2008 | 06:05 PM
krewat's Avatar
krewat
Actually, I was able to clamp mine on. One 2.5" extension, and it worked just fine. I did double-clamp it at the 3" end, but ... hey...
Old Oct 21, 2008 | 11:18 PM
85F_150driver
I ended up makeing one like the ebay y pipe i noticed a small gain but not sure if it was worth the hasle. But i did chew up a honda and spit it out on the highway. I am very impressed with the performance outa this truck so far though.
Old Oct 21, 2008 | 11:34 PM
5.4L to Freedom's Avatar
5.4L to Freedom
I've found a tonneau cover, gibson performance exhaust + cat delete, and a light foot is the best thing for mileage. The paddle mirrors are a helper too. Oh and iridium plugs seemed to make a great improvement!
Old Oct 22, 2008 | 06:36 AM
350z's Avatar
350z
5.4 to freedom , where did you find the cat delete ?
Old Nov 11, 2008 | 12:01 AM
85F_150driver
I am currently running a custom exhaust, replaced Y pipe, no cat 3" turbo, did it all myself at work. Had a local mechanic I trust put a set of plugs in it and that helped with power not sure about mileage because someone reset my trip odometer at half tank. He put a set of Autolite Double Platinums in seem to help. I managed to find a like new topper cheap and had it painted white to match my truck. With my heavy foot i get about 10 in town. for cat delete you need a 3" pipe about 24" long swelled on both ends with clamps or welder if i remember right.
Old Nov 11, 2008 | 08:47 AM
1975StroppeBaja's Avatar
1975StroppeBaja
Hmmm.... so you got the ebay pipe and clamped it on? Did you just use some short pipes to splice it in place? Do you have any pics of it installed?
I'd like to install this pipe but I've been holding off since its weld-in.
Thanks,
Jason
Old Nov 11, 2008 | 01:17 PM
krewat's Avatar
krewat
Thanks,
Jason
I'm afraid to post pics of it - it's ugly
But it doesn't leak.
What I did was to take the y-pipe out of the vehicle, line up the new y-pipe, and cut VERY conservatively leaving lots of extra length on the downpipes. I was lucky, and got it just right.
On the straight section of the ebay y-pipe, I used a 2.5" extension, it's about 6 inches long. The inside diameter of 2.5" exhaust pipe was about the same size as the OUTSIDE diameter of the stock downpipes - which is not "regular" diameter - it's not 2.5 or 2.25, it's right in the middle, like 2 3/8", but not exactly. Nor is it a "normal" metric size either...
The downpipes are not angled the same way as stock anymore, but I did get them straight on from the header flanges, so it all worked out pretty good.
Maybe I'll take a pic ...
03F2504x4
Jan 16, 2018 04:39 PM
dutchhman
Apr 29, 2009 09:23 AM
ericmarino
1997 - 2003 F150
Apr 28, 2009 12:05 AM
85F_150driver
Modular V8 (4.6L, 5.4L)
Oct 14, 2008 01:27 AM
jake47
Exhaust Systems
Oct 11, 2007 10:29 AM
