Explain HEUI Oil Shear?
Old Oct 13, 2008 | 08:27 PM
snakyjake's Avatar
snakyjake
Question Explain HEUI Oil Shear?
Can someone please explain the HEUI system and how it relates to oil shear?
I also may need some background on how hydraulic electronic unit injection works.
My assumption has been that an electronic device triggers the fuel injectors via a pathway of oil/hydraulic, and the oil actually doing the open/close of the fuel valve. But people also bring up that the HEUI system is really tough on oil from oil shear. So I don't quite understand where the shear is.
Thanks,
Jake
Old Oct 13, 2008 | 08:46 PM
F350-6's Avatar
F350-6
I'll take a stab at this. The shear, as well as importance of anit-foaming agents comes from our HPOP (high pressure oil pump) that takes oil at normal pressure from the regular oil pump or LPOP (low pressure oil pump) and pressurizes it up to 3300 psi to fire the injectors. At 40 or 50 psi in an engine you don't have to worry about shear. At 3300 psi, it makes a difference.
Here's a link that explains the injectors. It has pictures, so it will be easier to understand than anything I type. PowerStroke
Old Oct 13, 2008 | 08:49 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Not so sure about the shearing as much as the need for an antifoaming oil. Our injectors are fired by High Pressure Oil Pump (HPOP) pressure. There are two rails in the heads that feed the injectors, one fuel and the other oil. The oil is built by the HPOP and fills the rails and injectors. When triggered by the PCM through the IDM, the injector fires a piston using oil pressure to push the fuel, this piston has a ratio that multiplies the existing fuel pressure in the injector and pushes it through the nozzle and into the cylinder.
That is the simplest way I can explain it to get to your answer. Now the answer is that the HPOP pressure varies from about 500psi give or take idling to up to 3000 on a stock truck. On "big oil" modified ones it can easily exceed 3800 in some instances sustained. I don't know how much shearing is taking place there but know that the HPOP could foam up some inferior oil for sure.
There is a lot more technical way to explain the system but I just thought I would simplify to answer the question.
...and now I see before posting another answer is at hand. Do a search if needed.
Old Oct 13, 2008 | 10:32 PM
Pocket's Avatar
Pocket
Here in an article on oil shearing from BobistheOilGuy: Effects of Shearing
Hopefully now you can see after reading the article, why adding an HPOP to the setup will cause additional shearing. Add 2 HPOP's (like my truck) and even synthetics have a hard time making it to 5000 miles.
Old Oct 13, 2008 | 11:02 PM
randomhero1172's Avatar
randomhero1172
Switch from rotella to delvac about 7,000 ago and the last 1,000 miles ive noticed foaming - oil or something else? Great reading and info - thanks guys
Old Oct 13, 2008 | 11:03 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
It's just that normal engine oil is designed to be used in 15-80psi engine oil pressure sytems, and sometimes it can get as high as 3880psi on a powerstroke.
Old Oct 14, 2008 | 12:19 AM
jtharvey's Avatar
jtharvey
That's a pretty good read and has a lot of good info. Shearing can almost be thought of as breaking down the actual molecules of the oil, so they can no longer do the job of protecting the wear areas in the engine.
The radial piston pump that is the HPOP puts a lot of pressure on the molecules of the oil and causes them to shear. It's basically the high pressures between the two metal parts that causes it. Oil under pressure alone will not shear it, but the hard parts that are putting it under pressure will shear the oil in the area where the hard parts are making contact with each other.
Old Oct 14, 2008 | 05:26 AM
Kwikkordead's Avatar
Kwikkordead
It's one of the reasons that I change out my oil every 2000 miles using Mobil 1300 Delvac 15-40.
It's not synthetic, but where I live and the frequency of oil changes makes no sense to use a syn.
Frequent oil changes are a LOT less expensive than replacing expensive engine parts due to loss of lubrication!
Old Oct 14, 2008 | 07:58 AM
clux's Avatar
clux
Hey Kwikk did you know Mobil is doing their $3 a gallon rebate on delvac again this month?
http://exxonmobil.cmail4.com/e/525093/61jjdtj4t/
Old Oct 14, 2008 | 08:15 AM
F350-6's Avatar
F350-6
Thanks for the tip Clux. Now I just need to find where I can pick up 3 5 gallon jugs for my $45 rebate.
Old Oct 14, 2008 | 09:22 AM
Kwikkordead
I heard about that, but I'm so busy with work, and personal stuff that the rebate is going to pass me by this time.
I buy oil by the barrel from a wholesaler and don't even know if the rebate applies to that sort of purchase.
FWIW buying oil by the barrel is not any cheaper than buying it by the case and sometimes more expensive.
But not having to manage a half a dumpster full of empty containers that have to be treated as something you cannot just throw in the landfill more than makes up for it.
Old Oct 14, 2008 | 10:29 AM
snakyjake's Avatar
snakyjake
Some great info posted! Especially good reading from bobistheoilguy.com. The site gave me a much better understanding of the shear caused by the engine.
However, the HEUI oil shear is something I'm still trying to get my head around. From the sounds of it, the HEUI system places a lot of pressure on the oil. This high pressure is causing the oil viscosity to breakdown more quickly.
Does that sound right?
Old Oct 14, 2008 | 10:35 AM
Pocket's Avatar
Pocket
It's not necessarily the high pressure itself that causes the shear, it's the way the pumps work, like what JTHarvey explained. It's those moving metal parts that cause additional stress to the oil.
Old Oct 14, 2008 | 09:23 PM
jtharvey's Avatar
jtharvey
Yup. It's not the pressure, but the oil being squeezed between the moving metal parts that make that pressure. It's obviously a very thin film that gets squeezed and sheared at one time, but as the miles add up, the more molecules you have that have become sheared until it's to the point that the viscosity suffers.
Old Oct 14, 2008 | 09:39 PM
snakyjake's Avatar
snakyjake
Ahhh...okay. The high pressure oil pump is where the shear is coming from; in regards to HEUI.
Thanks to everyone!
