Fords high performance engines
Ok guys what Ford HP motors are available after the 460?. Who sells these high performance Ford motors? What kind off prices are we looking at.Just trying to learn a bit here. Im just a guy learning a bit about motors. Can you guys help me out. Thanks for your time
This is the Ford Racing crate motor site with the $9950 521 engines:
Ford Racing Performance Parts [Big Block Engines]
As to "what Ford HP motors are available after the 460", the 460 never came as a HP offering stock. While having huge potential and ability, most 460s were "Low Performance" pillow-barge motors, made to move 5000+ lb land yachts without turning more than 3500 rpm. PI versions had options more in line with increasing durability during extened idling at the donut shop.
"After the 460"...actually, the 460 was still around when Ford finally put some power back into the 302 (5.0 Mustang motors about the same net power as '60s Hi-po 289s) Turbo 4 cylinders don't count much, imo. Then there is the dohc 4.6 and 5.4. Supercharged, they are quite "Hi-po". The 5.4 in the Ford GT has been tweeked to 1000 hp with stock internals. I'd call that hi-po....
Ok, is that the road you wanted to go down?
Are you looking for more 460 info ( see prior post suggestion re 460.com) or other info?
Note the Ford racing site has the 302 & 351 motors, and a host of others as well.
Dirty Offio
13
Apr 23, 2017 10:54 PM
DieselCamper
23
Aug 10, 2016 06:58 PM
guitartruck
28
Feb 23, 2016 06:51 PM
billygoat1
23
Aug 4, 2014 12:18 AM
