Stuck Hub
Old Oct 14, 2008 | 06:02 PM
zx250's Avatar
zx250
Of the next Riffraff East
Oh, didn't mention, but mine is automatic, but the auto/lock markings are worn off, but hey, for 8 bucks and change.........
Old Oct 14, 2008 | 06:28 PM
pmasley's Avatar
pmasley
They are auto, I have a pair of the manuals that are in qreat shape. I had to use them on a friends truck a few years ago to get him home.
ZX, how far is Concord from Winston?
Old Oct 14, 2008 | 06:33 PM
zx250's Avatar
zx250
Winston Salem? near Greensboro? about 40 miles.
Old Oct 14, 2008 | 06:48 PM
pmasley's Avatar
pmasley
Well, I might just try to talk you in meeting me, hell have a lunch and just swap parts.
Old Oct 14, 2008 | 06:50 PM
zx250's Avatar
zx250
I will be driving up to Kerr Lake on the NC/VA line in less than a month, if you can wait, I'll bring it to you.
Old Oct 14, 2008 | 06:52 PM
pmasley's Avatar
pmasley
Where is that at?
Old Oct 14, 2008 | 07:09 PM
zx250's Avatar
zx250
Straight up I 85 on the state line. I will drive right by Winston-Salem on the way there and back. My other hub was like yours and I broke the center when I put a wrench on it to get it to lock. It locked and free'd up but I just got tired of fighting the vacuum lines, vacuum pump, hub failures in general. Now the Warns.
Old Oct 14, 2008 | 08:30 PM
jdecker88's Avatar
jdecker88
I would just got with the manual warn hubs because I am cheap and I like them to work heh. It cost me 8 dollars to send my old auto hubs to Guzzle two weeks ago so that wasn't too bad.
Old Oct 14, 2008 | 08:52 PM
pmasley's Avatar
pmasley
ZX is sending me one and once I change it out, I will send the two to guzzle. He can experiment and see if he can figure out what is wrong with the dang things. I do have a set of factory manual ones(they will not work on an auto sustem) available.
Old Oct 14, 2008 | 09:33 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
With my Warns, I use a pair of pliers with rubber-coated handles and put the handles inside the **** to turn it easily... They are somewhat recessed inside the chrome cap.
Maybe with a screwdriver and the pliers handles, you could move that hub?
On the other hand, maybe you should just throw the manuals in there and drive with the hubs locked. I lock mine at the first snowfall and leave them in all winter, and just use the **** on the dash whenever I need 4x4.
Doesn't harm anything, and if anything, makes the needle bearings (inner spindle bearing) last longer
Old Oct 14, 2008 | 11:11 PM
pmasley's Avatar
pmasley
Art, that idea has crossed my mind. I just wonder if they are sealed like the autos are. That is all that I would need is another vacuum leak to trace down.
Old Oct 15, 2008 | 04:03 AM
tjc transport's Avatar
tjc transport
i ain't rite
i make a "key" out of PVC pipe for locking and unlocking the hubs. it only cost about $3 to make, and is very handy for hard to turn hubs, or when you have gloves on in the winter and the wheel in hub deep in snow.
every one of my trucks has one in it.
Old Oct 15, 2008 | 07:07 AM
  #28
pmasley's Avatar
pmasley
TJ, now that is an idea. thanks. I will have to do one of those.
Old Oct 15, 2008 | 08:30 AM
  #29
krewat's Avatar
krewat
Doesn't matter - pull the vacuum hoses off the vacuum solenoid and plug them. Or, just disconnect the electrical connector from the solenoid, that's even easier.
Old Oct 15, 2008 | 09:49 AM
  #30
Ponyboychris's Avatar
Ponyboychris
Originally Posted by krewat
...Or, just disconnect the electrical connector from the solenoid, that's even easier.
That's what I did. I'll need to find time to pull and plug the lines at the hubs someday...
