Offroad & 4x4
coil spring spacers
Old Nov 27, 2000 | 05:48 PM
visegrip's Avatar
visegrip
coil spring spacers
has anyone out there ever tried using coil spring spacers to raise the front of there truck ? they are a lot cheaper than taller coil springs i just dont know if they work as good. thanks.
Old Nov 27, 2000 | 09:15 PM
FTE Ken's Avatar
FTE Ken
coil spring spacers
My personal experience: I broke a coil spring hitting a speed bump with a spacer installed. No kidding. :-(
Ken Payne
Ford Truck Enthusiasts Admin
Old Nov 27, 2000 | 10:05 PM
jopey's Avatar
jopey
coil spring spacers
just thinking about them would make one wonder.
I mean you are spreading the spring and putting excessive strain on one part of the spring. possibly spreading it past where it was intended to be. thus weaking the total strenght of the coil!
If it is still running. you didn't try hard enuf!
Old Nov 30, 2000 | 02:14 PM
Chuck P.'s Avatar
Chuck P.
coil spring spacers
Check some places that deal with jeeps, I know that they have spacers that go under the coil for a modest amount of lift, 1 or 2 inches at the most. These just raise the whole coil from the bottom with a spaced type perch. Don't know if anyone makes them for us guys though.
Old Nov 30, 2000 | 09:47 PM
DannyP's Avatar
DannyP
coil spring spacers
I tried some of the rubber spacers that fit between the coils and it was a lot of hassle for nothing. I don't think there are any spacers that go under or on top of the coil for our trucks, all the ones I have seen are for springs with round seats and the ones on mine aren't round, sort of "D" shaped. I'll eventually install some leveling coils I guess.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Dec 1, 2000 | 09:09 PM
JoeB's Avatar
JoeB
coil spring spacers
I have seen spacers that go under the spring in between the axle housing.I think they are only 1/4" thick and are mainly used for leveling purposes side to side. I guess you could use them to compensate for slightly sagged springs.There is no such thing as a cheap way to change the ride height as any change will require an expensive wheel alignment.I think your best bet would be to stay away from the spacers,new springs aren't that much.
Joe
94 Bronco XLT,5.8,E4OD
Old Dec 2, 2000 | 01:45 AM
mrlaserboy's Avatar
mrlaserboy
coil spring spacers
Superlift sells the coil spring spacers that go beneath each coil. Each spacer is 1/4" thick and you can stack them to a maximum of 1" lift. The info is at http://www.superlift.com/ford4.htm
Dustin Siebert
mrlaserboy(No Email Addresses In Posts!)
Registry: http://www.superford.org/cgi-bin/sf.cgi?uid=default&vr2=1&ID=201
Home Page: http://www.fortunecity.com/silverstone/gear/40
'88 Bronco XLT 302EFI/AOD/BW1356/44IFS with 8 lugs(open)/10.25 FF(Lockright locker)/4.56/6" Superlift/2" BL/35's-street/38.5's-trails
2 BIG BRONCOS 4X4 CLUB - GREAT LAKES CHAPTER
http://www.superford.org/users/ylobronc/fest/chinamansgulchsmall.jpg
Old Dec 3, 2000 | 09:01 AM
Kenny's Avatar
Kenny
coil spring spacers
ravens fan
18
Feb 23, 2011 05:46 AM
MemOrex
Jul 12, 2009 06:49 PM
Desert Dog
Bronco II
16
Dec 15, 2006 09:39 AM
864x2mudder
18
Mar 4, 2004 04:52 PM
