Coil spring spacers.
Old Feb 25, 2004 | 05:19 PM
864x2mudder's Avatar
864x2mudder
I went to Advance auto parts yesterday and was lookin around at off road stuff. I came across some things call ed coil spring spacers. The bow says that they help wore out springs. My springs are fine but will the spacers lift my front end any?
Old Feb 25, 2004 | 06:48 PM
8 Lugs's Avatar
8 Lugs
Yes they will! As long as the spacers are bigger than the spaces between the coils.
They also work great for snowplows!
I had a Bronco with sagged front springs, installed 2 twist-in spacer knuckles at the lowest coil of each springand brought the front end up for 12 years!
Before hooking up quick-disconnect snowplow, added 2 more spacers per side. It rode level with the plow up!
After plow removal, removed extra spacers. This did not damage springs at all!
Good luck!
Old Feb 25, 2004 | 07:10 PM
864x2mudder
Thanks I will have to make a purchase at Advance soon!
Old Feb 27, 2004 | 10:10 AM
BigCrzyRdNeck's Avatar
BigCrzyRdNeck
are those the rubber ones and will they work on a one ton?
Old Feb 27, 2004 | 03:58 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
A one ton doesn't have coils. One tons have leafs, but you can always put lift blocks in those.
Old Feb 27, 2004 | 08:07 PM
8 Lugs's Avatar
8 Lugs
Only the 3/4 and1 ton 4 wd have front leaf springs!
All the rest have coil springs.
The spacers I used were aluminum twist in spacers, approx. 1" thick (coat with wd-40 and jack front end up before installation)
Old Feb 27, 2004 | 10:45 PM
fishmanndotcom's Avatar
fishmanndotcom
if you put blocks under the front springs I am gonna smack you! that is the most un-intelligent thing you could do!
-jason-
Old Feb 29, 2004 | 04:53 PM
Redneck-Cowboy
Whatta you suggest, flip em?
Old Mar 1, 2004 | 09:22 AM
fishmanndotcom
flippin them won't work.....i tried! i made my own front leaf pack from a f150 rear leaf pack so that i get more/thinner leafs which means softer ride and better flex! it was easier than anyone thinks!
-jason-
Old Mar 2, 2004 | 07:24 AM
BigCrzyRdNeck
fish man you seem to not know your trucks becuase i have a one ton with coils and shocks. some 4x4 have leafs and super dutys have leafs.
Old Mar 2, 2004 | 10:34 PM
fishmanndotcom
how do i not know my trucks?
Only the 3/4 and1 ton 4x4 have front leaf springs, the rest have coil springs.
in answer to YOUR question....no they are NOT rubber....they are metal and are like a screw in the way that you insert them in a space in the coil and "screw" them into the coil to lift it!
-jason-
Old Mar 3, 2004 | 12:04 PM
BigCrzyRdNeck
some 3/4 ton 4x4s have coil springs on a twin I-bean 4x4. I know becuase a good friend of mine converted his over to leaf spring strait axle after he riped one side off mudding.
Old Mar 3, 2004 | 05:20 PM
Redneck-Cowboy
I'm with fishmanndotcom. I have yet to see a 3/4 and 1ton w/ coils, are for sure that was a 3/4?
Old Mar 3, 2004 | 05:52 PM
BigCrzyRdNeck
yes later converted to 1 ton front in with strait axle
Old Mar 3, 2004 | 07:53 PM
hoxiii's Avatar
hoxiii
I'd like to see proof of that. A 3/4 or 1 ton ford 4x4 with coils? Are you sure it wasn't a 250 4x2 that he converted to 4x4 using a TTB 150 axle?
Ford did some weird stuff, but ithink that's even beyond them. I know some 1/2 tons (supercabs) had leaves out front.
Justin
