Sponsored by: Real Truck
2007 f-450 headlight problem
Old Oct 12, 2008 | 05:14 PM
cpl624's Avatar
cpl624
Greetings gentelmen.
I am a Firefighter in Missouri and have a 2007 F-450 ambulance in my station. This morning the passenger side low-beam headlamp stopped working. By noon the driver side also stopped. The bulbs were replaced with no change. The fuses all seem to be okay. The high-beams work just fine, and will wig-wag when turned on. I called the ambulance body builder and got no help, with them saying it is a ford problem. Does anyone on here have any suggestions? I would like to be able to put this ambulance back in service today, and not have to be in an old International.
Thanks for any assistance.
Rick
Old Oct 12, 2008 | 08:29 PM
riggz's Avatar
riggz
Unfortunately it does sound like a Ford issue as the low beams shouldn't be modified with the wig wag. Check the relays?
Old Oct 12, 2008 | 10:31 PM
cpl624's Avatar
cpl624
I did some more thinking about it and wonder if the wig-wags may have caused a wiring failure similiar to the ones I read about the people using the HID headlamps. I saw several posts about folks who did not upgrade the wiring and it caught up to them. The ambulance has been in service 3 months now, and I wonder if the pulseing wig-wag on top of the low beam lamp, would cause the same type failure?
Old Oct 12, 2008 | 10:44 PM
rebelyell618's Avatar
rebelyell618
hopefully this could help.
https://www.ford-trucks.com/forums/7...t-working.html
Old Oct 12, 2008 | 10:52 PM
jake00's Avatar
jake00
Any chance its under warrenty?
Old Oct 15, 2008 | 10:32 AM
cpl624's Avatar
cpl624
Found the problem. It is only on the ambulance package and it's a computer problem. See TSB 07-16-6 involving the smart junction box or generic electronic module.
Thanks for your assistance in this problem.
snknby123
33
Dec 10, 2017 05:55 PM
golfmedik
6.4L Power Stroke Diesel
15
Dec 17, 2010 04:26 PM
DarrelEMT
Sep 29, 2008 09:04 AM
___
May 29, 2006 08:55 PM
mediccuz
Feb 2, 2006 05:14 PM
