Sponsored by: Real Truck
hub problem
Old Oct 14, 2008 | 12:00 PM
getnbz's Avatar
getnbz
hub problem
the dealer told me that the spindle bearing could be ok it could be the overall hub bearing could be bad. how do you check that ? my spindle bearings are ok no play and full of grease wheel spins fine. but there still is a grinding i set the cruise on and and when you turn wheel a little like weaving back and forth you can feel grinding thru your feet thru the floor.
Old Oct 14, 2008 | 12:10 PM
Chatham's Avatar
Chatham
I had the same problem in my 2004 F350 superduty twice on my left side with the stock hubs, I ended up replacing the stock hubs with warn heavy duty hubs and never had a problem again.
Old Oct 14, 2008 | 12:20 PM
getnbz's Avatar
getnbz
i have warn locks i mean the wheel hub
Old Oct 14, 2008 | 12:37 PM
Chatham's Avatar
Chatham
Could you see any sratchs in the bearings or small metal chips like it going bad.
Old Oct 14, 2008 | 12:57 PM
SpringerPop's Avatar
SpringerPop
Does it still grind with the hub locks in the locked (not "auto") position?
If the noise goes away with them locked, it's the needle bearings inside that have gone dry. Leave them locked until you can service them. See:
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Leaving them locked will only cause your front drive axles to turn, but you won't be in 4WD.
Pop
Old Oct 15, 2008 | 08:34 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
With the truck in 2-wheel drive with the wheels straight ahead, reach around back of the wheel and turn the u-joint by hand. It should be somewhat hard to get started, but when moving it should be smooth and not gritty or ratchety.
Old Oct 15, 2008 | 11:44 AM
getnbz's Avatar
getnbz
springer i have warn hubs and yes it does with hubs locked in or out
neeedle bearings are full off grease i grease every 6 months so i can kinda rule that out
