Honest opinion, please
IF you have 4.30 gears ina V10, you can tow 400 more lbs. than me on the fiver. Put in 3.73s like mine, and I have you by almost 3000 lbs... And that's because the GVWR is the same if you have 4.30s, but I outweigh you, so I lose the 400 lbs in towing capacity. So, if somebody wants to knit-pick specs, there they are. I still wouldn't want to pull 13k+ with a V10 for long distances.
EDIT: I wouldn't want to pay the fuel bill for a V10 with 4.30s, especially pulling 13.6k...
That's what wasn't cool about this tangent starting. He was stating rated facts and you just backed that up.
It's not nit picking, it's LEGAL.
The weight of the diesel takes away from the available GCVWR. If you needed all of that available to be in a trailer you could get it with the gasser but you'd be overweight towing the same one in the diesel.
That's not to say that the diesel couldn't do it, or do it better, but it has nothing to do with big rigs or anything else, it just comes down to weight.
My wife and I bought our 2003 Cedar Creek 36RLTS and drove it off the lot with a 1995 F-250 460 V8 4x4 stock tires 4:10 rear axle with a Banks header, cat delete, and 3.5" exhaust.
It would, at best, get 6 mpg and be down into first gear on 6% grades grinding up the hill at 25mph.
Got my current truck; a 1999 F550 7.3 4x4 six speed with 4.88 rear axle.
Same trailer, different truck, stock tuning. I now go up that same hill at 45 mph in third or fourth gear.
Mileage is a little better, if I stick to 65 towing then I get better than 9mph. Go 70, then it drops to 7.5.
I hope this helps.
Anyway, I rarely tow, but when I do, I don't want to have to worry about weight so much. Big thing for me is reliability. Historically, diesels have greater longevity, and the last thing anyone wants is a breakdown.
To the OP I would say "do the math" at first. Meaning, figure out what you'd save in fuel, and balance that against what it would cost to buy the truck you want. The "proof in the pudding" will be if you can borrow or go along for a ride with someone in a truck similar to what you want, and see how it does pulling that load.
Anyway, thank you all for your input.
Jim
Too bad I was not on much this weekend.
Between the 8.1 gas GM engine, and a Ford diesel, you WILL see an improvement in MPGs.
POWER? Dunno... I'd think the 6.0 would outshine the 8.1 easily, but the 7.3 might not be as big a bump as you'd think.
Thread closed.
