Sponsored by: Auxito
Adding a Second or third battery
Old Oct 11, 2008 | 10:01 PM
86moneypit's Avatar
86moneypit
I have been toying with this idea for about 6 months now, i want to add more high power electronics and a second alt. now since i have a 5.4L i figured i could get the kit off an f-250 with the same motor. In order to add more batteries i was wondering if i could mount up the battery box from an E-Series Diesel van which would give me room for 2 more batteries without having to cram them in less desirable spots.
Thanks for any ideas
Old Oct 11, 2008 | 10:17 PM
DirtStripHero's Avatar
DirtStripHero
You must be running a ton of electrical stuff to need a second battery and alternator. I would suggest just buying a better battery. I work on police interceptors all the time and they just run a single optima battery. And they run tons of lights and radios and a laptop. I would suggest something similar. It would be easier and cheaper.
Old Oct 11, 2008 | 10:20 PM
86moneypit's Avatar
86moneypit
Thats what i was thinking, but after talking to a few different people who use whinches, they seem to want all the power you can supply to them. The one guy was running a Yellow top battery and a 200 amp alt and he said it was just barely enough
Old Oct 11, 2008 | 10:39 PM
DirtStripHero
Ok. I didn't know you were running a winch. That makes a huge difference. I don't know much about them, and I don't want to give you any faulty advice, so I am going to leave this topic up to people who know about them. You may try posting in the Offroad forum though. They might have some pretty good suggestions
Old Oct 11, 2008 | 10:42 PM
86moneypit's Avatar
86moneypit
Well i dont have one yet, i dont see the point of getting one to have it not work lol. so im trying to figure out what i need to make the winch perform properly before i get it. and thanks so much for your help.
Old Oct 12, 2008 | 06:24 AM
Bobby82490's Avatar
Bobby82490
When using a winch, it is a good idea to have 2 batterys. You dont want to be stuck out in the middle of nowhere... and then your battery and alternator not being strong enough, long enough to pull you out.
There is a few pictures floating around here I believe of someone fitting 2 optimas in the orginal battery tray. They turned them sideways and they fit.
My suggestion would be to get 2 optima yellow tops, and just a single high amp alternator. I wouldnt think you would need 2 alternators, just one powerful one. Something else that you must figure into wiring up a project like this, is the price of the heavy gauge wiring. Not only will you have to buy the wiring for the winch, but you must replace the wiring for the batterys and alternator, and certain grounds.
Old Oct 12, 2008 | 11:58 PM
Bluegrass 7's Avatar
Bluegrass 7
The important thing to know is what power leads and sizes to use and good terminal connections.
Often poor installation causes voltage drops that are blamed on battery capacity.
First what is the max. current draw under full rated load?
Then select the cable size appriate to pass this current.
Choose connectors for the cable ends on the same basis.
Lastly, how long will the current draw normally last in order to tell how much battery capacity to have.
Charging is a matter of how fast you need to recover battery drain and NOT to run the wench, for alternator size. As an example, a small 50 amp alternator will recover the batteries as well as a large one but just takes longer.
Good luck.
cadjak
35
Sep 16, 2015 08:12 PM
myblkex
Dec 6, 2012 12:28 PM
Bbasso
Jul 23, 2011 05:25 AM
huntinzombie
Mar 28, 2008 10:01 AM
Nightrain
Electrical Systems/Wiring
Feb 28, 2007 08:22 AM
