Adding second battery to 2005 E350 with V10
Old Jul 16, 2011 | 10:39 PM
Bbasso's Avatar
Bbasso
Question Adding second battery to 2005 E350 with V10
I would like to add a second battery to my 05 E350, I'd also like to use as much OE parts as possible.
Could anyone assist in what I need?
thanks.
Old Jul 17, 2011 | 05:06 AM
JWA's Avatar
JWA
Just curious but why the second battery?
Old Jul 17, 2011 | 09:30 AM
PStruwing's Avatar
PStruwing
I would like to do the same thing as kids have drained the battery twice now watching TV and listening to both stereos at same time!
Not on immediate to do list, but if easy.....
Old Jul 21, 2011 | 09:18 AM
Motomedic's Avatar
Motomedic
From my research, I found the frame has the holes for the OEM battery box from the diesels. A quick run to Fleabay netted me two of them for less than $100 w/shipping. I haven't actually installed them yet, but it's a common thing.
Then you'll need some sort of isolator/charger/switchie thingie. I like the Hellroarer Tech version:
Hellroaring Technologies, inc., Manufacturer of Solid State Dual Battery Isolator / Combiners
After that, some wire and cable, and Bob's yer uncle.
Old Jul 21, 2011 | 09:25 AM
PStruwing's Avatar
PStruwing
Great info. Thx
Old Jul 21, 2011 | 02:52 PM
2000Ford2000's Avatar
2000Ford2000
A battery jumper box would be a LOT cheaper, but if you must:
Anybody add a second battery? - Ford Truck Forum | F150 Forum | Ford SUV Forum - FordFullsize.com
Ford factory E-450's and E-550's cut-aways already have twin batteries. Not sure if cut-away E-350's are made anymore. Used for RV's and Ambulances if you didn't already know that.
We've discussed this here before years ago but I need to leave work now and so I don't have time to search for it.
Old Jul 22, 2011 | 12:24 AM
Bbasso's Avatar
Bbasso
why?
so I can have power, I use my van for work and the radio plays for hours and some lights run too.
I'd like the OE battery box like I did on my 7.3PSD Van.
Old Jul 23, 2011 | 05:25 AM
JWA's Avatar
JWA
Originally Posted by Bbasso
why?
I thought this was your reason and I too run my van's radio, added interior cargo bay lighting and 12v accessory ports since its an outside work truck. My parts/materials have to be kept warm too during colder months so I did something a bit different---added a RV-type 12 volt converter.
Any device or outlet I wanted to operate that would normally draw power from the battery was wired into the converter in such a way that the chassis battery was taken out of the loop when shore power is applied. There is a 120 VAC heater too but none of it was that difficult to wire together.
All this assumes of course when you're parking and running things you have access to 120 VAC---I do so it was easy to do. You might not have that luxury which makes adding a second battery understandable.
America
Jan 6, 2018 01:24 PM
blackturbo
Nov 1, 2016 09:52 AM
joshofalltrades
15
Oct 7, 2016 03:36 PM
Im50fast
Aug 11, 2016 11:47 AM
Dace
22
Jun 9, 2016 12:50 AM
