2000 RPM idle! HELP!!!
Old Oct 11, 2008 | 02:49 AM
big_tiger's Avatar
big_tiger
Arrow 2000 RPM idle! HELP!!!
Well here is the story. Bought a 95 F-150 truck that had a 4.9 with a thrown rod. We got another engine, and now the idle will not go under 2k RPM.
We sprayed all around the engine to look for changes in the idle. Nothing
Disconnected the IAC nothing, swapped the IAC with another (no clue if either are good).
Pulled vacuum lines and the idle goes down???
Base timing set at 10* with SPOUT removed.
Put pressure on the system and couldn't hear a noise of a leak.
With all the checking I did I found nothing. I did block the small holes in the throttle blades, and it did lower the idle about 500.
Have to double check for codes, but the last time I ran them it was fine. I haven't blocked the TB to see if it will still run.
95 F-150 5-speed
Old Oct 11, 2008 | 07:12 AM
Motorhead351's Avatar
Motorhead351
Could be a couple things.
Try this first.
If when you disconnected the vacuum lines, I assume from the vac tree (?), you plugged all open ports and the idle dropped to normal, check the vacuum lines themselves, as one of the hard vac lines is likely cracked or melted. Look beside the valve cover and behind, going to the TAB and TAD.
Try this only after youve verified all vac lines are in good condition.
If you find nothing there, then its possible, your TAB solenoid is bad.
Check the connections at the TAB and TAD solenoids (back of the valve cover).
Seems like what could be happening, is the bypass valve aka egr valve is open when it shouldnt be. Quick way to see, connect all vacuum lines where they should be. Then remove the vacuum line from the EGR valve and plug the rubber hose or hold it closed, if your idle drops, its the TAB.
Old Oct 11, 2008 | 10:03 AM
big_tiger's Avatar
big_tiger
Try this first.
I will try that. Could someone send me high res pics of there engine bay? I need to double check I have everything hooked up correctly vacuum wise. I mainly need the pas side, and what hoses are supposed to where from the coffee vacuum can.
Alex.hump@yahoo.com
Old Oct 12, 2008 | 05:51 AM
Motorhead351
I removed any and everything unnecassary to the engine function, so I cant help ya.
Old Oct 15, 2008 | 10:40 AM
big_tiger's Avatar
big_tiger
The idle starts off low then goes to 2000.
The throttle return spring is fine.
When we cover the throttle body it will still idle. The upper intake manifold gasket seems like it needs to be replaced. We plugged the egr nothing, pulled all the vacuum lines, nothing...
Could it pass without the smog pump???
Old Oct 16, 2008 | 06:26 AM
Motorhead351
BAD TPS or IAC?
I dont have emissions testing, cant help you there.
Old Oct 16, 2008 | 11:20 AM
big_tiger's Avatar
big_tiger
Well we fixed it. Bad upper intake gasket. Now we just have to replace the radiator, and get it inspected.
95F150Guy
Jan 2, 2011 11:47 AM
jawilla
May 5, 2009 07:44 PM
muscletruck7379
May 12, 2008 12:51 AM
ErnieX
Mar 21, 2007 09:58 AM
jcstratt
1997 - 2003 F150
Jan 31, 2006 11:28 PM
