TEXAS.....married/divorced
Old Oct 10, 2008 | 07:54 PM
z 97ford1's Avatar
z 97ford1
Ok you texans, If a guy marrys a girl in texas and then gets divorced how much does she get and how much do u loose?
Does she get half of what you owned prior to marriage or do u get to keep EVERYTHING you had?
Old Oct 10, 2008 | 07:59 PM
FTE Herman's Avatar
FTE Herman
It depends on the attorneys involved.
Old Oct 10, 2008 | 08:03 PM
jimdandy's Avatar
jimdandy
Marriages in Texas fall under what is called the "Community Property Law.: Unless there is s pre-nup, property is divided equally. If you have kids, she gets child support in a divorce unless you get the kids, which is rare in Texas. No alimony in this state. jd
Old Oct 10, 2008 | 08:45 PM
jake00's Avatar
jake00
cheaper to keeper
Old Oct 10, 2008 | 08:53 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by jake00
cheaper to keeper
Say it again:
YouTube - Johnny Taylor--It's Cheaper To Keep Her (1973)
Old Oct 10, 2008 | 09:49 PM
wizzard351's Avatar
wizzard351
aw it usualy like this YouTube - Jerry Reed -- She Got The Goldmine (I Got The Shaft)
Old Oct 11, 2008 | 05:16 AM
cjben's Avatar
cjben
the better question is if after a divorce in texas is if the woman you were married to is still your sister!!
Old Oct 11, 2008 | 08:32 AM
kw5413's Avatar
kw5413
There are provisions for alimony in Texas...
2. spouses in ten-year marriages who can't support themselves.
the duration of the marriage was 10 years or longer, the spouse seeking maintenance lacks sufficient property, including property distributed to the spouse under this code, to provide for the spouse's minimum reasonable needs, as limited by Section 3.9605, and the spouse seeking maintenance
(A) is unable to support himself or herself through appropriate employment because of an incapacitating physical or mental disability;
(B) is the custodian of a child who requires substantial care and personal supervision because a physical or mental disability makes it necessary, taking into consideration the needs of the child, that the spouse not be employed outside the home; or
(C) clearly lacks earning ability in the labor market adequate to provide support for the spouse's minimum reasonable needs, as limited by Section 3.9605. Family Code § 3.9602(2).
Old Oct 11, 2008 | 12:02 PM
quaddriver's Avatar
quaddriver
pre-marital property is generally off the table, even in the land of fruits and nuts (CA), but any appreciation is not (and conversely, depreciation)
Old Oct 11, 2008 | 02:18 PM
Ship Boy's Avatar
Ship Boy
Temporarily Deactivated
In North Carolina ANYTHING thats acquired during the marriage is a 50/50 split except inheritance. Anything that someone leaves you in their will belongs just to you and the spose cant touch it. Things like pensions have to be split.
Old Oct 11, 2008 | 04:03 PM
jimdandy's Avatar
jimdandy
I don't know why you posted this as it is not a damn bit funny. Also, you are old enough to know better. I am very offended, and have lose any respect I might have had for you.jd
Old Oct 11, 2008 | 04:17 PM
quaddriver's Avatar
quaddriver
well its not like anyone was from west virginia
Orin Martin's Avatar
Orin Martin
As of yet I have not seen a clear cut set of laws that define how things should go that a lawyer cannot work around and change to suit the one who is fighting the hardest with the best and have enough money to back the play. It did not always go to the one that should have. If you have ever seen any thing any different it more than likely said “Produced by Walt Disney Studios”, for any others all I can say is WOW! You were lucky.
Disclaimer: My views are not intended to favor one gender over the other; I have realistically seen the door swing both ways. I have said before that stupidity does not follow a color code; neither does it follow a gender.
Old Oct 11, 2008 | 04:49 PM
cjben's Avatar
cjben
it was just a joke. I was born in Mo.,so I have heard all the jokes,have never taken them seriously
if i truly offended you,i am sorry
Old Oct 12, 2008 | 09:56 AM
kw5413's Avatar
kw5413
Sounds like you are running for President....
Geez, I saw nothing for you to apologize for....unless? Well, never mind.
