>Thanks all for the replies, the idea
>is to keep it as simple
>as possible, though my truck has
>the dual piston calipers, which I
>would prefer to keep, but if
>I have to use the leaf
>spring set up, I will.
>I was hoping that I could
>with minor changes using a 1/2
>ton Ibeams and 3/4 spindles.
>One of the things I don't
>have and have not been able
>to find, are leaf springs for
>an F250 4 X 4 with
>a diesle motor. Anyone have
>any ideas where I could locate
>one?
>Dave
><a href="http://members.aol.com/deleontow/auto/index.htm">http://members.aol.com/deleontow/auto/index.htm</a>
Dave,
What about having springs made for your application? National Spring is one company that comes to mind, or you could try aftermarket replacement springs made by suspension companies such as Superlift, Skyjacker, Tuff Country, etc. I'm sure they have the springs you need. Could you let me know if and when you have sucessfully adapted 3/4 ton spindles and such onto the 1/2 ton axles? E-mail address is mrlaserboy(No Email Addresses In Posts!).
there is a post in here way back in april or may about a guy who did the 3/4 ton swap to ttb axle. i think he actually used gm and ford parts. sorry i don't have exact info. i'll try to find it this weekend.
