99 surging, running rough, dies
I thought it might be water in the fuel because this started the day after I filled it from my transfer tank. But the water in fuel light has never came on. I put a new fuel filter on it but it made no difference. Have pulled filter three times looking for water but never found a drop. Also pulled several buckets from the bottom of my transfer tank but found no water there either. Any ideas on where to look next? I appreciate any help!
After some reading, I pulled the plug off the ICP. It had oil in it. I've left it unplugged and it has ran fine the 25 miles I've driven it since. Not to say that it won't mess up again but it hasn't yet. I might try driving with it unplugged this weekend and if it doesn't mess up again I'll get a new one. Thanks for the help!
Perform KOEO on Demand Test
Retrieve Continuous Trouble Codes
KOEO Injector Electrical Self-Test
Fuel Pressure Tests
Injection Control Pressure Tests
Cylinder Contribution Test
Boost Pressure Test
Data List Monitoring Parameter:
ICP, ICPv (KOEO) Spec 0.20v - 0.30v , FUEL PW: 1 MS - 6 MS, V-PWR, DC% - Cranking NTE 20% / 65% is closed. (IPR Suspect), MAT: Manifold Air Temperature the PCM uses this signal to adjust fuel and timing, Known Good Sensor KOEO Voltage:
AP: 5 volts in, 0.5-0.7 volts at idle, 4.5 volts at WOT. PID: AP
BARO: 5 volts in, @4.6 volts/14.7 psi at sea level, decreasing as altitude increases.
CMP: high, 12 volts, low, 1.5 volts.
EBP: 5.0 volts in, 0.8-1.0 volts/14.7 psi
EOT: 5.0 volts in, 4.37 volts@32°F, 1.37volts@176°F, .96volts@205°F.
PID: EOT (degrees)
EPR: Exhaust Back Pressure Regulator, also EBP regulator Output: For quicker engine warm-up at cold temperatures. If the IAT is below 37°F (50°F some models) and the EOT is below 140°F (168° some models) the PCM sends a duty cycle signal to a solenoid which controls oil flow from the turbo pedestal. This causes a servo to close a valve at the turbo exhaust outlet. The PCM monitors the EBP input to determine if the EPR needs to be disabled to provide power for increased load, then reapplies the EPR as load demand decreases until EOT or IAT rises.
IAT: 5 volts in, 3.897volts@32°F, 3.09@68°F, 1.72@122°F.
ICP: 5 volts in, 1.0volt@580psi, and 3.22volts@2520psi.
EXBP 10-15psig w/ EBPV closed and not exceed 45psi at WOT Note: EXBP showing low (3-5psi) that barley rises with acceleration indicates bad sensor or plugged tube.
IDM: 110 volt signal to the injectors. Grounds each injector as fuel is required for that cylinder. Fuel Pulse width is increased to deliver more fuel. The IDM sends a feedback signal to the PCM for fault detection.
IVS: 0 volts at idle, 12 volts off idle. PID: IVS (off/on)
MAP: Frequency output; 111Hz / 14.7 psi, 130Hz / 20psi, 167Hz / 30psi.
IPR: Coil OHMS = 10.2 - 10.6
If you can record data to compare following an event that's great. Then we'll have something definitive to review.
