Need know. 89 and 93 Door are same?
Old Oct 8, 2008 | 05:14 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
I will get 89 F150 for free next week I know it have replace door with no key from junkyard no keys so i am afraid use this in Detroit.
my mind pop that my 93 F350's 2 door look ok I say it not lock great due rust in it. Will they interchange?
Lock or door will interchange? Can I remove lock from 93 door and install on 89 door?
Old Oct 8, 2008 | 05:24 PM
skaterbro's Avatar
skaterbro
No, it won't work. It's '80-'91 for the door locks.
Old Oct 8, 2008 | 05:40 PM
andym's Avatar
andym
Why don't you just take it to a locksmith and have them make a new key for the door? Seems like a lot less work.
Old Oct 8, 2008 | 06:57 PM
pc_2000's Avatar
pc_2000
I think the lock mechanism should be the same. I replaced my locks from the junkyard out of an even older F150. I just had to swap the plastic arm on the locks. They just clip on. They were easy to change. Don't even need to take the door panel off.
Open the door, there is a metal tab on the edge of the door. Grab it with Channel-locks and pull it loose from the door. The lock mechanism will come out of the door. Remove the lock bar, check your plastic arm with the new ones, swap as necessary, reconnect to the lock bar, reinsert lock and then reinsert the metal tab. I did mine in about 10 mins.
Old Oct 8, 2008 | 08:20 PM
jk89cat's Avatar
jk89cat
the door shells are the same , yes you can use the later doors on the early and visa versa, whats different? 92-97 used a cable style internal door latch inside where the 91- used rods the later model and a nothed vent window for clearing the edge of the dash board to the poster who said the door locks are differnt , your right but only for 80-81 with slide locks and the exterior cylinder was still the same . you can actually use any of the doors from 1980 -1996 and 97 hd i had an 89 and a 91 on my 80 bronco i restored.
Old Oct 8, 2008 | 08:22 PM
quaddriver's Avatar
quaddriver
the door shells are the same. one part per side. however, trim panels - different, mechanisms different, glass trim and glass different.
but they ALL change over.
factory doors with 'not too much rust' are hot items right now. I can sell every one I get at carlisle each year without asking.
Old Oct 8, 2008 | 08:24 PM
Milwaukee1979F150
Can they do? I know they can but how they know what shape key it was on junkyard door?
How much that would be? $30?
Old Oct 8, 2008 | 08:29 PM
86F150302's Avatar
86F150302
Why cant you just buy new locks with keys from Auto Zone? Thats what I did. It was $9 for 2 locks and 2 keys.
Old Oct 8, 2008 | 08:34 PM
quicklook2's Avatar
quicklook2
i can't really understand what you are asking.
why do you always want to do things the cheapest and most difficult way?
just buy a new set of locks.
Old Oct 9, 2008 | 06:08 AM
jr32560's Avatar
jr32560
the earlier years are shorter keys-the mid 90s are 10 cut keys-they have 10 pins as opposed to the 5 pin tumbler-the locks look longer to me-new ones from a parts store may be much easier-heck swap the whole door-that will work they have the window and lock buttons in a much better spot anyway
jake_whitman
Oct 10, 2014 11:02 AM
jerryst
Jun 26, 2014 04:05 AM
BogTroll
Mar 2, 2014 07:05 PM
catbird7
Jan 22, 2014 09:42 AM
Hawke
Mar 20, 2009 05:30 PM
