Offroad & 4x4
Axle shock brackets
Old Mar 31, 2001 | 06:51 PM
mjb1962's Avatar
mjb1962
Axle shock brackets
For a Ford 8.8" axle in a 1989 F150, does anyone know if the shock brackets that are welded to the rear axle tube are sold separately?
Mark
Old Apr 3, 2001 | 11:36 AM
windsorizer's Avatar
windsorizer
Axle shock brackets
Yes, I have seen them at my local Auto Value pats store. This leads me to believe that Carquest would carry them. The only problem I could see is fabricating upper brackets(if you are creating a quad shock setup)---but if you only need replacments, they are availible.
Old Apr 4, 2001 | 06:52 AM
ford4x4offrd's Avatar
ford4x4offrd
Axle shock brackets
I would fab anything you need, that way you can custom make it and make it work, if those resources are not available then i would go and try to buy them. good luck
-Jacksland
Old Apr 9, 2001 | 05:39 PM
mjb1962's Avatar
mjb1962
Axle shock brackets
Thanks for the info, I think I will try to fabricate some and weld them to the axle.
Mark
Old Apr 10, 2001 | 08:07 AM
ford4x4offrd
Axle shock brackets
f1501987
101
Jan 17, 2012 09:23 PM
dfishrmn88
2004 - 2008 F150
Feb 4, 2008 06:33 PM
fishmanndotcom
Aug 14, 2002 05:55 PM
