Hood tilt-kit recommendations
Old Oct 7, 2008 | 10:35 AM
edzakory's Avatar
edzakory
I have lost patience with the stock hood hinges/alignment issues.
<o></o>
I am debating the purchase of a hood tilt kit for my ’56 F100 and would like to hear the experiences/recommendations of those you have one installed and whether it cures some of the coaxing/cajoling movements for closing/opening the stock hood configuration.
Thanks for any advice.
Old Oct 7, 2008 | 11:30 AM
sdetweil's Avatar
sdetweil
I love the MMB flip kit I got from MidFifty.. only downside is access to the radiator area... see my gallery
sam
Old Oct 7, 2008 | 12:37 PM
Jag Red 54's Avatar
Jag Red 54
Yes, get the hood tilt kit. It works much easier than the stock unit and the fit can be adjusted. See my gallery. I have heard that the aluminum billet units are harder to use that the steel units like mine. Good luck, Jag
Old Oct 7, 2008 | 02:19 PM
Randy Jack's Avatar
Randy Jack
I like the BMW flip hood kits also. If you are interested in something a little different, you can build your own forward tilt like I did.
If you remove the end clips on the air lifts and pull two pins, the hood comes right off the truck. This has proved VERY handy.
The whole gallery: https://www.ford-trucks.com/user_gal...&albumid=16500
Good luck.
Old Oct 10, 2008 | 01:14 PM
oldmanrvr5's Avatar
oldmanrvr5
Hood tilt
I am doing a slide tilt on a 56 fiberglass front end. The brackets are all hand made see pictures in gallery.
Old Oct 10, 2008 | 04:39 PM
edzakory's Avatar
edzakory
Thanks guys for sharing your ideas. It’s great to see that American ingenuity is still alive and well. I am somewhat humbled by your abilities. I am relegated to kits as I do not possess the fabrication talents that some of you portrayed. I bought a one-piece fiberglass front end for my project ’56 and sold it as I had no clue how to fabricate a lift. Now that you’ve shown me all I can say is “wow”.
<o></o>
I have determined that the reverse tilt-kit will not solve the front hood alignment problem. The hood sticks up about ½” inch in the front passenger side whereas the right diver side is aligned. Both the back side appears okay as well. I have to get the passenger side fender in alignment first since the kits use the front hood latch. I tried adjusting the dowel but that puts a lot of spring tension on the latch.
<o></o>
I don’t want to say anything derogatory about the Ford engineers of the ‘50’s since I have seen the commercial that shows the hood being closed with one hand. But when cab mount arms, hood alignment rods, fender alignment rods, and hood latch holes are needed to properly align the hood, all I can say is “uncle”.
Old Oct 10, 2008 | 04:43 PM
sdetweil's Avatar
sdetweil
Originally Posted by edzakory
<o></o>
<o></o>
there is a great post by AxRacer on how to get the front end setup and aligned properly. couldn't find it this second myself..
Sam
don7070
50
Jan 7, 2026 07:59 AM
edzakory
Mar 16, 2017 10:44 AM
jrockdiddy
Jan 13, 2016 09:01 AM
kotadawg
Oct 14, 2015 12:27 PM
bighalt56
Mar 20, 2011 06:18 PM
