Sponsored by: Kumho
Master Cylinder question
Old Oct 7, 2008 | 10:34 AM
imlowr2's Avatar
imlowr2
I recently did a disc brake conversion from all drum to all disc. I redid all the lines and purchased a GM Master cylinder. The one with large reservoir bowls for the front and rear. The front disc work great, the rears seem to not have enough pressure to push the pads to the disc. Lines are bled fine. I heard that the MC for disc and drum have a small seal or something that can be removed at the MC if your using rear disc? Anyone familiar with this? I believe the MC I bought may be for a disc drum application.
Old Oct 7, 2008 | 11:40 AM
Ford_Six's Avatar
Ford_Six
Did you change out your proportioning valve as well? You will need to replace that with an adjustable one, as the disk brakes require a lot more pressure than the drums.
Old Oct 7, 2008 | 11:43 AM
imlowr2's Avatar
imlowr2
I have a wilwood adjustable proportioning valve in the line going to the rear disc brakes. It is set at wide open and I'm not getting enough pressure to the calipers.
GoldCo
18
Apr 30, 2016 06:48 PM
FordStolz68
Mar 10, 2016 09:45 AM
clr0gers
1947 and Older Ford Trucks
Jul 7, 2014 08:26 AM
flattie39
Mar 23, 2014 11:57 AM
IAmKevin
May 30, 2013 12:07 PM
