How to do shim to raise fuel pressure?
Old 10-07-2008, 02:04 AM
TTFord07's Avatar
TTFord07
TTFord07 is offline
Couldnt find the info on how to do this mod, how do I do this and how can I set up a gauge to read the fuel pressure? I was looking at the fuel pressure regulator kit diperformance.com sells, but dont feel like dropping the 500 for the kit at the moment.
Old 10-07-2008, 05:47 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is online now
Have you measured the fuel pressure?
Without going into a long explantion, it has been found that anything over 65-70 psi makes it worse. The engine/injectors, etc seem to work best with that.
With that said, there is this, Diesel Innovations sells an adjustable fuel pressure regulator that you can change out the shims with.
EDIT: here is the link. CLICK HERE
Old 10-07-2008, 07:40 AM
jhand124's Avatar
jhand124
jhand124 is offline
Kwik, I looked into that, but I don't think they sell them anymore.
TTford07, you can go here to purchase a gauge, you can mount one in the cab which requires an isolator so you are not running fuel to the gauge in the cab or just mount on under the hood.
I would hook up a gauge first to see if you even need to shim the FPR.
If you do need to increase pressure you can do the #4-40 hex head bolt shim.
I tried to find the thread on it but the search function is not working.
Try searching FPR shim.
Old 10-07-2008, 11:20 AM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
My 99 runs stock about 68 lbs, which is ideal with my fuel gauge.. Like Jason say, measure your pressure first..
Old 10-07-2008, 12:30 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Here is a photo write-up on shimming the FPR. But you need a fuel pressure gauge before shimming the FPR so you know the before and after pressure!
Shimming FPR
Even shows how to install temporary fuel gauge.
I knew I had seen this before. I googled "FPR shim". Use the quotes.
Old 10-07-2008, 06:00 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
Old 10-07-2008, 07:06 PM
PaysonPSD's Avatar
PaysonPSD
Dan
Kool, that's the rest of it. The good link, same guy, same pics, but with better explanation.
endobear
11-03-2014 09:07 AM
99StrokeXLT
27
03-23-2013 09:34 PM
reeder65
01-13-2012 03:21 AM
redbull660
07-18-2006 09:36 PM
emboyd
1978 - 1996 Big Bronco
04-06-2002 07:30 AM
Quick Reply: How to do shim to raise fuel pressure?
