Resistor Identification?
After a failed attempt (lasted about a week) to repair the board I cross referenced the machine and found it also came out with manual controls to which I changed it out to. All I know for sure is that washer worked for a long time and still worked when I sold it.
Same here. Sears Kenmore Elite, if memory serves me.
There is one resistor on the board that is way too small (1/4 watt instead of the needed 1/2 watt.)
I've replaced that board twice in 4 years, for $65.00 a pop!
I'm gonna replace the resistor with a 1/2 watt and see what happens.
We're always close by when the washer and dryer run. (It's usually me that is closer. I wonder how she does that?)
P=IE, power = current times voltage
E=IR, Voltage (E) = current times resistance.
P can be no more than .25 (1/4 watt)
R = 39 ohms.
Current can be expressed as Voltage over Resistance.
substituting into the power euqation:
P = E/R*E, therefore P=E^2/R
E^2 = P*R
knowing what we know, E^2 = .25*39 = 9.75, square root of this is 3.12 volts
check our work, 3.12v/39 ohms = 80ma
80ma * 3.12v = .2496watts
so now, turn on this thing with no resistor and measure the voltage presented at either end of the resistor, with respect to ground.
Bigger than 3.12v, go looking for why
