06 F150
Oct 6, 2008 | 02:52 AM
06 F150
Does anyone know if Ford offerd trucks this year with a towing package but hitch?
Oct 6, 2008 | 06:04 AM
Oct 6, 2008 | 12:22 PM
my '06 has tow pkg. with receicer but, no but hitch. I did have a but head run into my trailer ball; it makes a good jap raidator drain
Oct 6, 2008 | 01:02 PM
Quote:
Originally Posted by
jsoko
I had a lady slam into the back of my 84 Bronco with a Chevy Malibu... well my hitch/ball made quite a nice radiator drain....
To answer OP question.. Yes Ford offered a Tow Package on '06 F-150's quite a nice one if you ask me!
No sure what a "But" hitch is?
Oct 6, 2008 | 01:43 PM
cwj06, not sure how to tell if that '06 has tow pkg. might check for oil cooler & trans cooler or possible VIN code(from dealer). Someone could have removed the " but hitch "
Oct 6, 2008 | 03:43 PM
I think that he is asking if maybe it just has the hitch and not the tow package upgrade, not sure ??
Oct 6, 2008 | 06:44 PM
but no hitch is what I ment
Oct 6, 2008 | 07:41 PM
a but hitch is something that occurs in your pants on an extremely hot day.
Oct 9, 2008 | 12:26 PM
my 06 came with the tow and go package and yes it has a factory hitch
Oct 9, 2008 | 02:05 PM
04-08 F-150 came 3 ways.
1. With Tow Package
Class IV Reciever
A 4 pin and 7 pin wiring harness
Upgraded Trans Cooler
8,000 to 10,000 lb capacity depending on wheelbase and motor/tire combo
2. Reciever
Only a Class III reciever I believe, nothing else
Limited to 5,000 lbs capacity
3. No Reciever
just a empty bumper
Oct 9, 2008 | 07:26 PM
Are you asking if it comes with a hitch/ball combo? If so then mine did not come with one. I bought a tri ball from Walmart.
Oct 9, 2008 | 08:10 PM
I had a nice man ram the back of my stopped '06 F150 with a maxima. my hitch not only made a nice radiator drain it made a solid front end compactor.
Oct 9, 2008 | 08:15 PM
I have the 144 inch wheel base 06 F150 and mine came with the hitch and trans cooler... I tow a good bit with my truck.
MArk
Oct 10, 2008 | 05:06 PM
jsoko
You can't remove just the hitch.. The bumper bolts to the factory hitch..
I guess you could and install whatever is used in the non-factory hitch model...
Although, if you had a factory "but hitch" maybe some baby powder would help remove it..
Haggs21
Mar 19, 2014 08:52 PM
Whitey Ford
Jul 4, 2011 03:40 PM
gunthet
All Things Towing
Jun 30, 2008 10:38 AM
LEROY06
New Member Introductions
Aug 16, 2006 07:44 PM
oldfordtrucksrule
2004 - 2008 F150
20
Aug 7, 2006 08:45 PM
