Question's about valve spring height
Old Oct 5, 2008 | 08:56 PM
SIXD9R's Avatar
SIXD9R
Hi,
I'm looking at a Crane cam and matching springs (Crane #96801). According to Crane, the installed spring height should be 1.800 but with no shims I'm measuring 1.930 and that's with the retainers (Crane #99957) Crane recommends to use with these springs. I was browsing the Comp web site and I looked at 4 different springs they recommend to use with FE cams. With Comp, 3 of those springs call for a 1.900 height that I can get with a shim but the fourth calls for 1.800 like Crane which looks to be impossible to get. I did notice with Comp all 4 of these springs are calling for different retainers. Can anybody explain the different height requirements and how does one get a .100 difference? Is it in the retainers? I know cups and locators are available but .130 seems like way too much. For the record heads are Casting # C80E-6090-N. Thanks for the help!!
Old Oct 5, 2008 | 09:06 PM
FEmtnmax's Avatar
FEmtnmax
I was never that far off the 1.800 spec. Have your valve seats been cut several times??
I think there's various retainers available that can vary the installed height.
I would HIGHLY Recommend buying Crane springs over Comps. The last set of comp springs I purchased had only 3 0r 4 of them meet their spec, the rest were 5-15 lb low out of the box. I returned them, and purchased Crane springs where every one of them met their spec.
Old Oct 6, 2008 | 09:25 AM
Barry_R's Avatar
Barry_R
Pretty common to see a big variance between OE and aftermarket parts. The factory spec for those heads is 1.8200. You are only .100 off. I'd run a .060 locator under the spring in any case - assuming the heads are machined for flat spring pockets. Otherwise you can purchase -.050 valve locks and/or retainers. You won't get to 1.800 nor should you - thats just a checking number for the spring.
Neither Crane nor Comp make their own springs. They are wound by either Associated or Petersen....depending on part number.
Old Oct 6, 2008 | 11:17 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Those springs (from Crane's website) show "Ford V-8 w/1.077-1.850" installed heights"
CraneCams
So even with a .060 spring locator, you're at 1.870
Sounds like your valve seats are sitting pretty low...
What's the lift on that cam?
Old Oct 6, 2008 | 03:58 PM
SIXD9R's Avatar
SIXD9R
I didn't see that on the Crane site. But if you look above it says "Seat Pressure @ Installed Height 114 lbs @ 1.800"
And also if you look at the cam sheet (Crane #343801) under the spring requirements it says:
Part Number 96801
Loads Closed 114 LBS @ 1.800 or 1 13/16
Open 290 LBS @ 1.240
So I called Crane with this same question last week and the guy I spoke was not very friendly but insisted I hit the 1.800 number.
I really don't know how many times the valves have been cut but I think I can guess at least 3 times, maybe that's the problem. I will probably call Barry about this since I'm probably going to buy from him anyway.
1972-34ton
Mar 18, 2012 11:29 PM
hunter1897
Mar 20, 2006 03:52 PM
rusty70f100
Oct 2, 2005 11:56 AM
oldblue31
May 21, 2005 08:13 PM
pkulaga
32
Apr 28, 2005 10:29 PM
