Posi unit ?
Old Oct 5, 2008 | 06:17 PM
edub32's Avatar
edub32
Posi unit ?
Will the 10.25 lsd posi unit fit in our 10.5 rear axle?
Old Oct 5, 2008 | 06:21 PM
DCSpecial's Avatar
DCSpecial
Carrier is the same.
When going through the effort, I'd go aftermarket....or at least shim up the factory LSD to make it tighter (clutches wear faster though).
Isn't "Posi" and GM term??
Old Oct 5, 2008 | 08:03 PM
BobbyDiesel71's Avatar
BobbyDiesel71
what do you recomend?
Detroit locker for the rear diff and throw posi in garbage??? LOL
dual ARB air lockers!!!!
Old Oct 5, 2008 | 08:15 PM
DCSpecial's Avatar
DCSpecial
I know some guys who have shimmed the stock LSD pretty tight and it works well, over time it gradually doesn't work as well as the clutches wear. Then you can rebuild it again when it is no longer acceptable.
Lots of guys like the Trutrac for a LSD.
If you need a locker, Detroit or ARB.
I run ARBs front and rear.
51M1
Oct 18, 2014 09:36 PM
The Freak
Offroad & 4x4
Dec 23, 2009 07:38 PM
Whiskey Bent
Mar 16, 2009 09:38 PM
afonda
Jan 31, 2009 03:46 PM
talldog
Jul 2, 2003 03:07 PM
