Offroad & 4x4
Posi Unit
Old Dec 22, 2009 | 05:00 PM
The Freak's Avatar
The Freak
Posi Unit
I probably shouldn't be posting a wanted ad here, but I haven't had much luck posting in the other areas. I'm looking for a used posi unit for a HP Dana 60 front, 4.10 carrier. Let me know if any of you have something laying around.
Much appreciated!!
Old Dec 22, 2009 | 11:40 PM
75F350's Avatar
75F350
MIght be able to ipen your search a little and find a Power Lock for a rear application. Many Dodge trucks had these in the rear for several years, and they can be found in the salvage yards.
The 4 pinion gear design is far superior to anything else out there in this category, and since you are going to rebuild it anyway, you can install 35 spline side gears and use it up front.
Old Dec 23, 2009 | 10:01 AM
The Freak's Avatar
The Freak
That's a great thing to consider!! Any idea what year/model is the best candidate in those Dodge trucks?? I'm assuming anything that had a 60 in the rear. If you found a rear posi from a Ford, would you be able to do the same thing to it (swap out side gears) and be able to use it in the front??
Thanks for the tip!!
Old Dec 23, 2009 | 05:41 PM
Prozon's Avatar
Prozon
Try craigslist. Probably find more selling there than anywhere else.
Marketplace - Ford Truck Enthusiasts Forums
Or that.
Old Dec 23, 2009 | 07:38 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Ed can you change Detroit locker side gears? I got a 30spl 60 and id like to cahnge it to 35spl. The locker i mean.
JackErnie
Jul 25, 2015 08:28 AM
obx 79 shortbed
Aug 30, 2014 10:20 AM
defiantoutlaw
Mar 20, 2014 06:57 PM
68fordf100v8
Aug 14, 2012 10:51 AM
Riso79
1978 - 1996 Big Bronco
Jan 6, 2002 07:54 AM
