01 Excursion with P0676 code
Old Oct 5, 2008 | 12:24 PM
aklim's Avatar
aklim
I have changed the entire driver side bank. Truck seems to start ok. A little smokey but it is cool out. That should have fixed it. But the light still comes back on.
A couple months ago, I had a CEL with a GPCM failure but that seems to have self resolved. What am I missing? Could the GPCM be at fault?
Old Oct 5, 2008 | 12:36 PM
aklim's Avatar
aklim
If it were the GPCM acting up, why not all the GPs and not just #6?
Old Oct 5, 2008 | 12:57 PM
PaysonPSD's Avatar
PaysonPSD
Have you checked the connectors at the GPCM?
What if you swapped the connectors you could isolate it to either the GPCM or the connector or wiring to the glow plugs.
If you got a P0675 then there may be a connector or wiring problem.
If you still get a P0676 it could be the GPCM. Worth a try.
Old Oct 9, 2008 | 11:24 AM
aklim's Avatar
aklim
I checked the wiring and it was about0.6 ohms from the VC harness to the negative terminal. All of them did that. Checked continuity from the GPCM and it was good. Swapped terminals and it had the same code. Changed the module, cleared the code and so far it hasn't appeared. We shall see.
Old Oct 9, 2008 | 11:31 AM
PaysonPSD's Avatar
PaysonPSD
Thanks for posting the fix. So swapping the connectors pointed to the GPCM. I don't have a GPCM, but this is good to know for those that do.
Old Oct 9, 2008 | 11:50 AM
aklim's Avatar
aklim
http://www.etruckfacts.com/whatsinside/DESCR.pdf
On the last page is a crude pinout
Old Oct 9, 2008 | 12:26 PM
PaysonPSD's Avatar
PaysonPSD
I have actually seen a better one and have it in my Potobucket LINK
DANA60
Aug 23, 2016 02:09 PM
Gruntface
Apr 30, 2012 05:37 PM
MeanGene427
Mar 6, 2012 09:36 AM
tom135
Dec 19, 2011 04:55 AM
