Clutch Chatter
Old Oct 5, 2008 | 10:41 AM
73cntry's Avatar
73cntry
Clutch Chatter
Can the clutch chatter when the trans is in neutral by increasing RPM then letting off the gas just between 675 and 1500 RPMs
Any help is greatly appreciated
Old Oct 5, 2008 | 06:36 PM
Cuda_jim's Avatar
Cuda_jim
If you still have a dual mass flywheel then Yes. It may be clutch time, get a single mass.
There many here that have an opinion on the best one. They should be along to give you more advice.
I've replaced a couple but don't drive one on a regular basis so I wouldn't know.
Old Oct 5, 2008 | 06:52 PM
73cntry's Avatar
73cntry
Unfortunately the dual mass is the original clutch still in there looked at it the other day had springs on the fly wheel. Also had some clutch material in the fly wheel cover so it's going. Hasn't started slipping yet though or do these clutches just go out at once when it's there time.
Thanks for the help and knowledge!!!!!!!!!!!!!!!!!!!
Old Oct 5, 2008 | 07:10 PM
the_old_ranger's Avatar
the_old_ranger
Solid flywheel replacement is the only way to fix this annoying problem.
Old Oct 6, 2008 | 09:40 AM
Neal 97 250's Avatar
Neal 97 250
I would go SMF as well but if you are interested I have a new in box clutch for the DMF. I will even throw the DMF in there for free if you want it.
Old Oct 6, 2008 | 07:22 PM
73cntry's Avatar
73cntry
Thanks Neal but if the SMF is that much better like a lot of you say then I'd go with that especially if it lasts longer plus works better too. Well I don't know much about the DMF anyways really except for what I read in here.
Thanks for the offer though I'm already changing out the fuel pump as well.
Just curiousity how much would you be asking?
Old Oct 7, 2008 | 07:03 AM
Neal 97 250
I believe it is around $228.
You made the right choice the SMF is the way to go. Why do you think I have a DMF clutch for sale?
Old Oct 7, 2008 | 12:28 PM
73cntry's Avatar
73cntry
It did sound like you had one for sale as I interpreted but the SMF sounds great
Tectron1
Apr 10, 2015 10:54 AM
mechelement
Jul 20, 2010 06:36 PM
Placermike
Washington Chapter
442
Jan 18, 2008 03:32 PM
Black89F150
Jan 12, 2005 02:35 PM
gtex
Oct 10, 2002 09:03 PM
