missing, stuttering, under load.. :(
Old Oct 11, 2008 | 02:26 AM
DJdemon6696's Avatar
DJdemon6696
no cat here.. MAP is cheked.. O2 is cheked maybe its the stator in the dist like you said.. im going to replace that next.. my EGR is blocked off... so i dont think thats the prob.. i have a new fuel pump and new fuel filter.. so its not a fuel problem its a spark prob..
Old Oct 12, 2008 | 03:09 AM
Opossum's Avatar
Opossum
In the begining you said .050 spaark plug gap shorten to .035 see if it gets better. I've seen problems like this many times and many times it's simpler than you might think. Sense it bot better when you changed the plugs I have the sense that you simply aren't getting enough power to the plug to jump the large gap causing a mis, it takes more power with more throttle. While I'm at it I don't suggest platnum plugs they don't stay clean. I do suggest the Taylor thundervolt 50 wires going from 300 ohms per foot to 50 can make a huge differance.
Good Luck
Old Oct 12, 2008 | 12:40 PM
DJdemon6696
Good Luck
thanks btw the stock gap for my truck is 0.43- 0.46 so im going to try in that range... thanks!
but dont you think its strange that only the 3 last cylinders on the passenger side plugs are missing. ?
nway i have a set of old plugs that i took of a while ago 0.43 gap im going to put them on the side that its missing
Old Oct 12, 2008 | 01:31 PM
Redcat Diesel's Avatar
Redcat Diesel
3 cylinders in a row would have me looking for a vacuum leak.
Old Oct 12, 2008 | 03:10 PM
DJdemon6696
what kind of vacuum leak ?
Old Oct 12, 2008 | 03:28 PM
Redcat Diesel
I don't remember the vacuum hose routing on a 5.8 but I'd start checking lines and fittings. There is also a gasket between the top and bottom sections of the intake manifold that can fail resulting in a major vacuum leak. Vacuum leaks can lean out a cylinder(s) to the point that it won't fire.
zukiboy
Jun 7, 2015 12:12 AM
zukiboy
May 27, 2015 09:45 PM
Deerkiller63
Dec 11, 2011 05:02 PM
hatchet
Offroad & 4x4
21
Feb 22, 2011 05:01 AM
RIJID-FORD
1997 - 2003 F150
Aug 25, 2009 06:36 PM
