Modular V10 (6.8l)
Sputtering
Old Oct 16, 2008 | 05:37 PM
yasky69's Avatar
yasky69
Ok, here is an update on this at this point.
Went out and bought a coil pack. I check the resistivity of the new pack and it read .9. I went through each coil pack and checked the resistance. I found number 5 to be close but a bit sporatic. So I replaced that one. Assuming the whole resistance thing. Well at first it seemed ok, no check engine light. Read my codes now a MAF low code comes up. Clean the maf again, didn't resolve the problem. Anyways since it seemed better decided to try it on the road. NOPE... sputter came back.
Now the only thing I can come up with at this point is to try moving the rest of the coil packs around to see if its another pack or not. And to buy a new maf sensor and while I'm at it replace the Map sensor as well. So at that point I will have replaced the 3 main sensors for air/fuel measurement. I really didn't think this was gonna be this difficult to troubleshoot.
Old Oct 16, 2008 | 06:46 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds like a heat-related issue with a COP. Do the round-robin thing, unless you can get the misfire counters read.
But "maf low" ? What code was it exactly?
Old Oct 16, 2008 | 07:07 PM
Fordsflylow's Avatar
Fordsflylow
Sounds alot like what mine did and it turned out to be a vac leak on the pvc line to the throttle body.
Old Oct 16, 2008 | 07:35 PM
yasky69's Avatar
yasky69
MAF Low voltage PO102 was the code.
I did check all my vac lines hand over hand
It doesn't matter if the truck is hot or cold, just come on randomly
Old Oct 17, 2008 | 01:10 AM
RACERX7775's Avatar
RACERX7775
mine has the same random sputter. no codes and no pending codes. the last 2 times, it was a bad coil. now, i just ordered a full set of 10 accel coils to fix it.
Old Oct 19, 2008 | 09:26 AM
yasky69's Avatar
yasky69
UPDATE
Well so far for the past two days its been ok. After moving around some coil packs it was when I changed out #7 that it seemed smoother. Keep your fingers crossed, and thanks guys for your help
Old Oct 20, 2008 | 08:49 AM
yasky69's Avatar
yasky69
ITS BACK!!
Spoke to soon yesterday. Outside temp this morning is between 20-30 degrees. It started this sputtering thing. I did get another code
This time PO355- ignition coil E primary/secondary malfunction. If "E" is the number 5 cyl then this is the one that has the new ignition coil on it. Furthest back on the passengers side.
Old Oct 23, 2008 | 05:08 PM
Big Orn's Avatar
Big Orn
I know this has been discussed before, but if you have good relations with a Ford dealer, let them hook it up to their Worldwide Diagnostic System (WDS).
You may have to get into a situation where you put the engine under load - like hooking it up to a trailer - so that the "sputter" can rear its ugly head.
When I get mine tested, the costs have varied from $45 to $65 depending on how long it took for the problem to surface. The longest time its been hooked up is about 45 minutes...and, as you know, it only takes a few minutes to replace the COP.
Old Oct 29, 2008 | 07:29 AM
yasky69's Avatar
yasky69
Its been running great the last 9 days, with no skips or sputtering.
I ended up changing all the coil packs on it.
Old Oct 29, 2008 | 07:43 AM
Big Orn's Avatar
Big Orn
Thanks for the feedback. Congrats.
Old Oct 30, 2008 | 04:33 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
For future reference:
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Oct 31, 2008 | 03:04 PM
Big Orn's Avatar
Big Orn
I saw your price - it says $45.00 for a single coil, but then listed a price of $339.00. What would be the price for 10 COPs?
Maybe I missed that, which ain't nothin new...
Old Oct 31, 2008 | 09:48 PM
  #28
RACERX7775's Avatar
RACERX7775
my guess that price would be for 8. thats $360 and with a tad bit of a discount might just be $339. just to let you know, there is a company in florida, REBELPERFORMANCE, on ebay too, that i got 10 brand new accel coils for $224 shipped to my door. i got them and they are exactly what he said they are. brand new in the box.... sure beats the junk china made coils and also beats the factory ford coils too.
Old Nov 3, 2008 | 02:20 PM
  #29
PerfDistIgnition
FTE Sponsor
It's not on the website yet.
We will send you a private message on the price due to the forum rules.
__________________
FTE Sponsor
Old Nov 3, 2008 | 03:39 PM
  #30
Big Orn's Avatar
Big Orn
That'll work
809taino
Modular V8 (4.6L, 5.4L)
Feb 3, 2013 09:15 PM
Drgslayr
1983 - 2012 Ranger & B-Series
Jul 16, 2009 02:49 PM
Jack-USAF
28
Nov 10, 2007 01:35 AM
blustang6614
1978 - 1996 Big Bronco
Jun 15, 2005 06:30 AM
nijwnfi
Bronco II
28
Sep 6, 2004 08:39 PM
