I just purchesed a 05 Excursion Limited 4x4 V10 45000k.
I went to change the Oil today and the yahoo at quakerstate put the oil filter on so tight it would not budge. In my attempt to get my filter wrench around the top of the filter I put a small crack in the Oil Cooler above the filter.
Well removal is not so simple.... You can not spin off the cooler without removing the whole bracket you can not remove the bracket with out it look like taking out the motor mount..... so... I clamped off the lines to the cooler drained the cooler and got out the JB Weld... first I sanded the surface rough and put down a good surface of the magic epoxy so far looks great... will fill the system and begin test tommrow...
