Sponsored by: Real Truck
suspension differences
Old Oct 3, 2008 | 09:08 PM
F-250 FX4's Avatar
F-250 FX4
so i recently bought a 2003 f-250 that has the fx4 package 5.4 and when i got it home a guy pulled up and was looking at it and i realized that mine is about 2 1/2 inches taller and has a heavier suspension than his truck which is 100% identical otherwise i was just wondering what different suspension packages were offered on this truck and how would i be able to tell if mine has a lift previously installed
Old Oct 3, 2008 | 09:36 PM
riggz's Avatar
riggz
Yours could have a leveling kit installed on it.
Old Oct 3, 2008 | 10:41 PM
aldridgec's Avatar
aldridgec
you could check the spring codes on the door jamb sticker under "spr". it is possible with a 5.4 to have a spring combination from the factory that makes it pretty tall, as well as firm.
Does it ride hard?
Old Oct 3, 2008 | 11:10 PM
F-250 FX4's Avatar
F-250 FX4
yes it rides pretty stiff and im not to sure about the leveling kit as it still as a pretty good rake to it the spring codes are TP
Old Oct 3, 2008 | 11:27 PM
PowerStrokeHD's Avatar
PowerStrokeHD
T code front springs are fairly light and not going to make it ride high compared to a similar truck with stock suspension. More than likely it has some sort of leveling kit or lift.
Old Oct 4, 2008 | 01:04 AM
cartmanea's Avatar
cartmanea
You should only have 2 leaves in the front packs, if there are more then a leveling kit has been added and makes it a lot stiffer.
Old Oct 4, 2008 | 05:27 AM
HeavyAssault's Avatar
HeavyAssault
FX4= Fancy looking shocks and some stickers
Old Oct 4, 2008 | 08:33 AM
F-250 FX4's Avatar
F-250 FX4
i will get some pictures of the suspensions and the spring codes off the actual springs today if anybody could help me out that would be great
Old Oct 4, 2008 | 09:47 AM
F-250 FX4's Avatar
F-250 FX4
here are the pics of the front and rear suspension
REAR
Front
Old Oct 4, 2008 | 10:07 AM
bwguardian's Avatar
bwguardian
Yep, you have a mild lift and level.
Old Oct 4, 2008 | 12:57 PM
F-250 FX4's Avatar
F-250 FX4
well if thats true is there any way to firgure out how much ?
Old Oct 4, 2008 | 01:06 PM
bwguardian's Avatar
bwguardian
The back has the 2" blocks (which is stock for the F250...the F350's had 4" blocks) and probably is only lifted by the two short spring pads on the bottom of the spring pack (hard to tell for sure from the pictures if there are additional leafs in the pack)...so maybe an inch in the back. The front also has the leveling short springs in addition to another leaf (came stock with two full length springs). The original two springs were more than likely not re-arched, so I would guess the front was lifted around 2". This would give the truck stance more level...as opposed to having a 2" difference between the front and the back like what was stock (the front being lower).
Old Oct 4, 2008 | 01:17 PM
F-250 FX4's Avatar
F-250 FX4
how many springs are supposed to be there stock? mine has 7 full size springs and the two small ones under them all
