Optimal use of block heater?
Old 10-03-2008, 03:25 PM
H1449-6's Avatar
H1449-6
H1449-6 is offline
Fall is here in Chicagoland and winter will be here soon enough.
I found that my truck, though it's from the south, has the block heater plug. Wondering what the best way to use this is.
At home, my garage will remain a minimum of 40 degrees. I guess I could keep it plugged in to make it easier to start in the morning but don't want to if it's just going to waste electricity.
At work, where I keep it for 9-12 hours, I could plug it in if I had to. At the airport, where I have to keep it for a few days sometimes, I probably won't have access to an electrical plug (though I'll look for one, I guess).
What's the best way to use the block heater?
Old 10-03-2008, 07:20 PM
JumpinJoe's Avatar
JumpinJoe
JumpinJoe is offline
block heater in the winter
I got my X 7.3 PS last year from FL. Carfax says it was a 100% southern car, so I was surprised myself last winter when I found the plug. Your winters shytown are just a little colder than NH's. I probably won't plug her in, until mid-November. Sadly she parks outside (won't fit in the garage). While I'll always plug her in outside, the extension cord inside the garage is usually unplugged.
Say it's going to be under 30* when I wake up, and I need to leave in about an hour. I run down to the warm garage and plug in the extension... do the coffee shower thing.... and she's good to go. I learned the hard way that plugging her in all night is unnecessary and VERY COSTLY. A tripled power bill that first month of winter was all the old lady needed to stop me from the all nighters. With this said, I would never plug her when she's parked in a place thats over 30*.
Old 10-04-2008, 07:52 AM
brooklyn born's Avatar
brooklyn born
brooklyn born is offline
since your from chicagoland, you know how cold it gets up here in appleton wi. i used to plug my 2001 7.3 PSD EX in overnite. if you go to my gallery of pics, you will see the end result. a garage fire that totalled my EX, 71 bronco being restored and my entire garage. the fire started in the area of the plug in. i now own a 2005 6.0 PSD EX in mint condition and i doubt i will plug it in at all this winter
Old 10-04-2008, 05:22 PM
cparks's Avatar
cparks
cparks is offline
I don't plug my 05 6.0l in unless it gets below zero. Starts fine and have not noticed any issues on the oil tests winter compared to summer.
Old 10-04-2008, 07:53 PM
H1449-6's Avatar
H1449-6
H1449-6 is offline
Sounds like I'll use it only in exceptional circumstances. Thanks for the comments.
Old 10-04-2008, 08:24 PM
MarkMoore's Avatar
MarkMoore
MarkMoore is offline
Northern or Southern - I believe that all PSDs came with block heaters.
Old 10-05-2008, 01:24 PM
bmenzel's Avatar
bmenzel
bmenzel is offline
I know all the 2005 PSD's had block heaters installed. But those Excursions sent to the South (Florida for sure) did not have the necessary power cord from the heater to the grille area included. However the cord was an option and could be ordered if desired. The factory cord is available from dealers for about $60.00.
Old 10-05-2008, 10:20 PM
UrbanXX's Avatar
UrbanXX
UrbanXX is offline
Engine Block Heater!!!!!!!!!!!
As far as I can tell an engine block heater is standard equiptment on all the Power Stroke Diesel Engines in Excursions no matter where they are sold.
03 Excursion
4X4 V-10
Limited
Keeping it real
Old 10-06-2008, 08:18 AM
cparks's Avatar
cparks
cparks is offline
Yes I think they all have the block heater, but most you have to install the cord on many of them. I had to do this with mine.
Old 10-06-2008, 04:22 PM
makaibob's Avatar
makaibob
makaibob is offline
Hi Guys ('n Guy-ettes if present),
I have a question, since the subject was broached, did they offer an engine block heater (factory, or factory accessory) for the V10? I've used engine block heaters on virtually all of my regular rides. I used a timer to turn on the heater about 3 hours before I leave the house, so the electric bill doesn't get out of hand. I seem to recall that someone once stated that it wasn't even an option on the engine/vehicle.
Thanks in advance,
Bob
Old 10-06-2008, 06:00 PM
MarkMoore's Avatar
MarkMoore
Yes, they did offer a block heater for he v10 as an add-on option - some people here have them (I just don't recall who). I bought one off ebay, but I have yet to install it.
droldsmorland
1999 to 2016 Super Duty
17
01-03-2017 02:54 PM
regret
26
11-10-2015 06:22 AM
Long Haul
6.2L V8
08-08-2015 09:47 AM
TrekChick
11-25-2008 09:41 PM
wmiller
35
11-23-2008 06:51 PM
Quick Reply: Optimal use of block heater?
