6.2L V8 Discuss the 6.2L V8
Pic Request (block heater)
Old Aug 7, 2015 | 07:56 PM
Long Haul's Avatar
Long Haul
Any chance if one of you with a 6.2L that has a factory block heater could take a pic of where the heating element goes into the block ??
I installed a Autometer water temp gauge and need a spot for the send in unit....My truck didn't come with a block heater so I'd like to use that soft plug is what I'm thinking..
Thanks
Old Aug 7, 2015 | 08:06 PM
Long Haul's Avatar
Long Haul
FYI if anyone is thinking of using one of these 46mm does not fit.....GlowShift will tell you it does but I can tell you it does not..
Of course I found this out on a Friday after I cut the upper rad hose to install it....It cost me $65 at the local Ford dealer to get another rad hose this afternoon....I had no choice having my truck down all weekend wasn't an option..
cheap ricer garbage is what that adapter is I should have known better....
Old Aug 7, 2015 | 11:18 PM
dirtymutt's Avatar
dirtymutt
I can't take a picture right now but it's on the drivers side right in the block. You probably just have a frost plug in that particular spot currently. It's probably a screw in factory block heater and not pressed in so it would be easy to just install a OEM one if the one you bought doesn't seem to work properly. You need to be under the truck to see it.
Old Aug 7, 2015 | 11:20 PM
dirtymutt's Avatar
dirtymutt
My bad I did not read your post properly. Yes that location would have a plug you might be able to use.
Old Aug 8, 2015 | 08:02 AM
Long Haul's Avatar
Long Haul
just wanna make sure I get the right plug..
this is looking up while lying on my back, drivers side next to the oil filter.
I suspect thats it just want to confirm now..
Old Aug 8, 2015 | 09:21 AM
dirtymutt's Avatar
dirtymutt
That's it. I crawled under this morning to double check for you.
Old Aug 8, 2015 | 09:47 AM
Long Haul's Avatar
Long Haul
Thank you sir much appreciated...
MotoPro193
Oct 9, 2016 09:58 PM
5.4f250sd
Dec 11, 2010 12:58 AM
bigb9582
13
Oct 10, 2009 07:27 PM
nut1605
Nov 5, 2006 09:33 PM
scar98
Modular V8 (4.6L, 5.4L)
Dec 19, 2005 09:48 AM
