need help asap
Old Oct 3, 2008 | 01:27 PM
otpracer100's Avatar
otpracer100
need help asap
guys, I have limited internet access. My truck won't go over 55 mph and it feels like it is defueling when you floor it. Put it to the floor and alot of blueish white smoke pours out. HPOP??? If you try to accelerate hard it won't shift and stays at about 2300 rpm. Let off the throttle and it will shift but not accelerate rapidly. In park the truck revs up fine. No tuner or chip in right now. Any help greatly appreciated. Thanks. Dave
Also tach works fine so don't think it's the cps.
Old Oct 3, 2008 | 01:39 PM
Neal 97 250's Avatar
Neal 97 250
Check the air filter to see if it is clogged. It shouldn't be defueling since it is making smoke, That makes me think not enough air.
Unplug the EBPV valve. The plug is under the turbo inlet, 2 wire. I wiil keep thinking and post back but here you go...
Old Oct 3, 2008 | 01:42 PM
Neal 97 250
My bet is the EBPV is stuck. If unplugging it doesn't work then you can go to the plunger and open it up and wire it open.
I guess it wouldn't hurt to clean the FPR screen but I don't think it could affect it that much and all of a sudden.
Old Oct 3, 2008 | 01:52 PM
otpracer100
EBPV HAS BEEN UNPLUGGED FOR YEARS. tHIS HAPPENED ALL OF A SUDDEN. nOT SURE IF IT WOULD BE THE FPR BECAUSE OF THIS. tHE AIR FILTER IS GOOD AS WELL
Old Oct 3, 2008 | 01:54 PM
Neal 97 250
How about the fuel filter?
Old Oct 3, 2008 | 01:56 PM
Neal 97 250
IS there enough oil? and is it in good shape. Sorry for the Duh questions just trying to isolate the easy ones. You may want to check the EBPV to be sure that it didn't close on you manually. just a thought
Old Oct 3, 2008 | 01:57 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
just a thougth: TPS??
Old Oct 3, 2008 | 02:44 PM
otpracer100
i WILL GET A NEW FILTER TOMMORROW. I HOOKED UP THE EBPV TO SEE HOW IT RUNS ON THE WAY HOME. wHICH ONE IS THE TPS? THANKS
Old Oct 3, 2008 | 02:50 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
there are 2 connectors in the fuel pedal, one is TPS and other the IVS that you should check.
Old Oct 3, 2008 | 04:09 PM
tjbeggs's Avatar
tjbeggs
Unplug the electrical connector of the MAP sensor (gray sensor on top of the A/C box with electrical connector and rubber hose going to it) and drive it. If it drives better you need a MAP sensor
Old Oct 4, 2008 | 07:24 PM
otpracer100
TJ if the map sensor is bad,it will have my symptoms? What am I looking to pay for a map sensor? Thanks. Also to everyone else helping, I hooked and unhooked the ebpv and left it in the open position with no change.
Old Oct 4, 2008 | 08:54 PM
tjbeggs's Avatar
tjbeggs
Yes it could be bad with those symptoms. They run about $150 last time I checked. Just unplug the connector and drive it. If it gets better you need a new sensor.
Old Oct 5, 2008 | 08:37 AM
otpracer100
Thanks TJ i'll give it a shot today.
Old Oct 5, 2008 | 09:37 AM
c00nhunterjoe's Avatar
c00nhunterjoe
blue smoke and no accell says o-ring is busted to me. while in park or neutral put the go pedal on the floor. if it runs right up to the limiter then they are most likely fine. my guess is it will rev quick and smooth to 1800-1900 then stumble pop and smoke really bad to about 2700-2800 then spin up to 3400 smooth.
Old Oct 6, 2008 | 06:55 PM
otpracer100
I want to thank everyone for all their help and suggestions. I've been away from the site for awhile due to some health problems. I'm glad to see the brotherhood is still alive and well. A special thanks to TJBEGGS for hitting it outta the park. It was the the map sensor. Thanks again to all.
Dave
