Sponsored by: Real Truck
Black smoke
Old Oct 3, 2008 | 10:05 AM
Silencer's Avatar
Silencer
Black smoke
Ran to Talladega and back(from New Orleans)yesterday and my '02 7.3 ran great,millage and performance was outstanding.......then it started to loose power,milage went away(big time) and the pipe went from clean to black.Black smoke even at idle.Injector control module? '02 7.3 with 77,000 miles. Thanks,Bob
Old Oct 3, 2008 | 11:45 AM
F350-6's Avatar
F350-6
Black smoke:
Caused by excessive fuel for the amount of air drawn into the cylinders. Some black smoke on hard accelerate or at higher altitudes is normal. Excessive black smoke could result from restricted intake or exhaust, inoperative leaking or weak turbo, intake hose(s) leaks, leaking or worn injectors, fuel return or supply restriction, stuck Exhaust Back Pressure Regulator valve or solenoid. Also PCM inputs such as BARO MAP ICP or EBP sensors.
Any other symptoms you can give us?
Old Oct 4, 2008 | 08:29 PM
Silencer's Avatar
Silencer
Black smoke
F350-6,Thanks for the reply..Air filter is new,air box modified to allow more than twice the stock volume,turbo boost 25+ lbs(dp Tuner chip)No back pressure valve,Retrun line is new with Aeromotive regulator set at 65 lbs.(stock reg. removed)Won't be able to scan it till Mon.This is excessive smoke all the time not just upon exceleration.I'm guessing IDM,temp sensor or bad injector. It's only got 77K on it.I hope it's the temp sensor($)but I'm not sure if PSD go full rich when the sensor goes bad. Thanks again,SemperFi
Bob
Old Oct 4, 2008 | 09:05 PM
F350-6's Avatar
F350-6
How did you modify the air box? Cut holes in the bottom of it? You might try disconnecting the MAP sensor to see if that makes a difference. That should cause the PCM to infer default values for the MAP sensor and may clear up the smoke.
You might also stop in a little further down the main forum listing and check out the 7.3 diesel section located here 1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums Lot's of knowledge about these motors down there.
Semper Fi.
Old Oct 9, 2008 | 01:07 PM
Silencer's Avatar
Silencer
Black smoke
Found the problem....#4 injector was bad,apparantly stuck open so fuel was just pouring in. Bob
tuskfire8
Texas Chapter
Nov 29, 2012 02:51 AM
Old93junk
General Automotive Discussion
19
May 2, 2009 09:58 PM
Jim McCarty
All Things Towing
Feb 25, 2009 05:04 PM
jabaker70
Nov 13, 2005 10:15 AM
PSD6litre40
Feb 7, 2004 03:04 PM
