Sponsored by: Auxito
Need A/C, heater expert...
Old Oct 3, 2008 | 09:53 AM
Thunder Road's Avatar
Thunder Road
On a '98 F150 w/4.6.
The hot air has stopped coming out.
I've heard it's the 'blend door' and will be checking that this afternoon,
BUT- when I have the setting on full WARM, and the selector on DEFROST, I can hear something cycling- I could swear it sounds like the A/C cycling on & off.
I can't recall ever noticing it before... is that 'normal'?
If it's not, what do I need to look for to make the A/C turn off and the HOT air to resume coming out?
Thanks...
Old Oct 3, 2008 | 10:37 AM
Club Wagon's Avatar
Club Wagon
You might not "Need A/C, heater expert". You "Need" to read the Owner's Manual. The A/C is supposed to run when the "selector is on DEFROST" whenever its above the minimum limit temperature of 50 F.
The A/C runs in every position except the PANEL or FLOOR positions & of course OFF.
A bad 'blend door' is a common failure, that's a PITA to fix, but so is a temp control **** spinning on it's shaft, which is easy to remedy.
projectSHO89's Avatar
projectSHO89
A/C operation is NORMAL during defrost. See your owner's manual.
Go to the HVAC forum and see the FAQs.
Steve
Old Oct 3, 2008 | 10:20 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/6...irections.html
