2003 Ford Expedition Window Stuck Down
Old Oct 2, 2008 | 07:51 PM
jaylynn's Avatar
jaylynn
I have the back window of my 2003 Ford Expedition stuck down. It worked very intermittently before, and my daughter rolled it down and now I cannot get it up by the door or the drivers door main panel. In actuality the only window that works is the driver door. The others are all stuck (only the one stuck down). Any suggestions?
Old Oct 3, 2008 | 01:22 PM
04markIII's Avatar
04markIII
probably a bad window switch. one day my drivers went down, but wouldnt come back up. eventually, hitting the switch enough, it did. i replced the switch, and no problems since.
Old Oct 3, 2008 | 02:55 PM
berry1234's Avatar
berry1234
Work the switches both on the door with the problem and the drivers numerous times with effort. If you manage to get it up, you need to replace the switch cluster on the drivers door. Check ebay, there are many of them.
Old Oct 3, 2008 | 07:24 PM
badltl510's Avatar
badltl510
I had the same problem with my old jeep grand cherokee. What I did till I got a new switch was open up the door and apply voltage right to the motor to get it up just an idea.
Old Oct 4, 2008 | 12:38 AM
alloro's Avatar
alloro
Is no one going to consider the possibility of the motor being bad?
Old Oct 4, 2008 | 01:13 AM
badltl510's Avatar
badltl510
If you apply voltage to the motor and it still does not work then you know it's the motor.
Old Oct 4, 2008 | 06:36 AM
broncoholic's Avatar
broncoholic
I'd consider the motor being bad if it was only one window. But what are the chances that 3 of the 4 window motors would be bad?
I'm voting for the switch cluster on the driver's door. Like badltl510 said, you should be able to apply voltage right to the motor and get the window closed till you can get a new switch. Once you do get it closed, hit the window lock button so noone can accidentally put their window down.
rbrad6937
Jun 3, 2018 12:06 PM
bigtexan99
Sep 13, 2017 08:46 AM
StealthWyvern
Nov 21, 2014 07:16 PM
billybobzia
1997 - 2003 F150
May 30, 2012 02:39 PM
jackiegibson
Jun 24, 2010 06:57 PM
