Possible GEM problem? Where is it located? 2003 Expedition
Old Oct 2, 2008 | 01:18 PM
pham34's Avatar
pham34
Need help. I have a 2003 Expedition XLT and when you first start up neither the p/windows or radio will work except for the clock and you can still load/eject cd's from the changer, but no radio or sound. Once the cabin is warmed up (10-15 minutes in cooler weather, shorter in warmer weather) the radio will suddenly turn on and the windows will then operate. If it is a sunny warm day and the cabin is at a high temp (estimate 90 deg. or higher) then there is no delay and everything works right from startup.
I have had truck checked for water leaks and everything is perfectly dry. It all has to do with temp. Even on a hot summer day if you run the a/c cool enough it will cause the radio/windows to shut down until you get the cabin warmed back up again. Problem has been going on for a year now. Called several dealerships and all they want is for me to bring it in. Does anybody know specifically if it is a GEM (BCM) and exactly where is it located in this model.
Thanks for any help.
Old Oct 2, 2008 | 02:52 PM
04markIII's Avatar
04markIII
no gem in the 03's. all done through fuse box and pcm.
Old Oct 2, 2008 | 03:06 PM
alloro's Avatar
alloro
Possibly a bad ignition switch. It might have to warm up and expand for the internal contacts to touch each other.
Old Oct 6, 2008 | 08:44 AM
pham34's Avatar
pham34
what is a PCM? I can hear a "click" comming from one of the modules when it does power on and have interchanged those with knowingly good ones and doesn't improve the situation. I'm just trying to avoid costly diagnosis time as much as possible. Thanks.
Old Oct 6, 2008 | 11:58 AM
04markIII's Avatar
04markIII
the pcm is the main computer(powertrain control module). it is located on the rh side of the firewall on your truck. big grey thing.
Inthswamp
Dec 24, 2016 01:55 PM
blumax
Mar 3, 2015 05:52 PM
miserableloser
Oct 21, 2012 11:25 AM
383STROKER
Oct 25, 2007 08:26 AM
Wobe72
Oct 26, 2006 05:14 PM
