Y-pipe Leak
Old Apr 12, 2013 | 01:18 PM
Craig.Parks's Avatar
Craig.Parks
Y-pipe Leak
During the process of changing out the oil cooler I noticed what sounds like an exhaust leak in the
Y-pipe on the driver side. During idle you can hear an air leak like a gasser that has a vacuum line unhooked.
When the vgt cycles the sound goes away.
Does this y-pipe come out from the top after the turbo is removed?
Anyone found a replacement y-pipe without the bellows or should I just go back with a oem unit? I still need the
egr up-pipe.
Oem is $247 from Tousley.
Old Apr 12, 2013 | 03:12 PM
Nice Work Truck's Avatar
Nice Work Truck
Yes it comes out the top after you remove to turbo.
I got mine from Elite and it is a LOT better than the stock one.
https://www.elitedieselengineering.c...haust-Bellows/
Old Apr 12, 2013 | 03:51 PM
Craig.Parks
Those look good. I googled and never found those.
Do you recall if the mount holes for the heat shield?
I have the ICP in the back.
Thanks for the link.
Old Apr 12, 2013 | 04:23 PM
Nice Work Truck
My 07 has the heat shield and it went right in.
Cell's
May 6, 2015 10:57 PM
dc2842002
Jul 20, 2013 03:26 PM
bigdummyford
Nov 24, 2010 10:29 PM
snowcan
Aug 23, 2010 01:38 PM
cdiddy
Jan 1, 2007 10:45 AM
