Need help identifying transmission
Old Oct 2, 2008 | 01:06 AM
CrazyB's Avatar
CrazyB
Hey all,
So for our '54 we picked up a 292 motor to replace the old seized up 239. It came with an automatic transmission, which is not going to be used, but I am trying to figure out what it is to get rid of it. It looks like some version of the fordomatic based on pictures I can find online, but after google searching some of the markings, it may be some version of a borg warner tranny. I'm hoping someone here can help identify it.
The markings are:
on bellhousing
PMB7976A W2
on transmission (located directly on top of the main housing)
5C-1
WG DIV
N 10
I have pictures of all of the marking if anyone would like to see them, and I hope to get some pictures of the whole thing sometime tomorrow if that would help.
Old Oct 2, 2008 | 11:22 PM
CrazyB's Avatar
CrazyB
It should be mentioned that this would be cheap/free to a good home if I can identify it and figure out if it would be worth something to anyone. At the very least someone might want the bellhousing, as it looks like it comes apart.
Old Oct 3, 2008 | 07:03 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I can't help with the numbers but if the pan has 11 bolts and perfectly square it's probably a C4. The C4 and the FMX both had a removable bell housing but the FMX is VERY heavy since the center housing is cast iron. It has a 13 bolt pan.
Old Oct 5, 2008 | 01:44 PM
CrazyB's Avatar
CrazyB
I just checked and the pan is held on 14 bolts and is rectangular with the long side oriented transversally. I don't know if this helps anyone.
Old Oct 5, 2008 | 02:49 PM
wmjoe1953's Avatar
wmjoe1953
Discription is a perfect match for the bone stock ford-o-matic auto trans available in thos days. They had a removable beel housing, and 14 pan bolts. I am looking at the picture of one right now in the Ford Illustrated Parts Catalog.
Old Oct 5, 2008 | 04:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
On the drivers side of the transmission case, is a Ford ID tag code riveted on with codes similar to these examples: PAR-A, PAW-A.
Post what you find.
You cannot go by the transmission pan to ID what type of transmission it is, because....
It could be also be a Cruise-O-Matic.
The Cruise-O-Matic uses the exact same (2) transmission pans a 3 speedo Ford-O-Matic does.
B5AZ-7A194-A .. Pan / 13 1/8" x 10 1/8" / 14 trans pan bolt holes.
Fits: 1951/57 cars / Some 1958/63 cars / 1953/60 F Series trucks / all small (FX) Cruiseomatics 1958/67.
B5SZ-7A194-A .. Pan / 13 1/8" x 10 15/32" / 14 trans pan bolt holes.
Fits '55/57 T-Bird / '56/57 Station Wagons with 292 4V's and 312's / all big (MX) Cruiseomatics 1958/67.
The C4 was introduced in 1964, the FMX in 1969.
Some peeps here confuse the FMX with the two earlier FX & MX Cruiseomatics.
It is not the same transmission.
Old Oct 5, 2008 | 04:32 PM
WALFORD'S 56's Avatar
WALFORD'S 56
Not to barge in-But---is the t98 4speed from my 1956 F600 a lot different than a 4speed in a F100? In other words does the 53-60 something trans look like the bigger truck trans?
I have a 272 and 4 speed I just pulled out of the 56 f600---is the 4speed the same as what the 56f100 has? Thanks and sorry to barge in.........Bill
Old Oct 5, 2008 | 04:59 PM
NumberDummy
--is the 4speed the same as what the 56f100 has? YES. Thanks and sorry to barge in.........Bill
I barge in all the time, must be a trait of guys named Bill.
1956 T-98 = F100/700 same-o, same-o.
The same case was used 1953/56, prior to 1953, the case is different.
There may be internal differences 1953/56, I'd have to take a look-see.
Be back is an hour or so, the war department aka "She, who must be obeyed," wants to go to the pottery place, cuz they have a sale going on....(sigh).
Old Oct 5, 2008 | 07:04 PM
WALFORD'S 56
Bill---Maybe the pottery place will have a nices ole effie sitting out front , and you can stare at it while--''she who must be obeyed'' shops......thanks Bill
Old Oct 6, 2008 | 07:38 AM
CrazyB's Avatar
CrazyB
Post what you find.
There is a tag, but from what I can tell, if anything what written on it - it has long ago been rubbed off. I had assumed that tag would give me everything I need, but of course couldn't read it. I will take a closer look this afternoon and see if if I can possibly pick anything up on it - but I doubt it.
Old Dec 13, 2008 | 06:18 PM
pcmenten's Avatar
pcmenten
I am hoping to impose on Bill for some help identifying two transmissions. I'm researching what it takes to adapt an FMX to a y-block and I think one method is to use a Cruise-o-matic front pump and converter. I found two transmissions in a rural boneyard with prefixes C5AF and C5MP and had two questions;
Are these Cruise-o-matics? And, what might the differences be?
Thanks Bill.
Old Dec 13, 2008 | 08:08 PM
Julies Cool F1's Avatar
Julies Cool F1
So, Bill, did you buy a little pot? On Sale?
Tee hee,
Julie!
Old Dec 14, 2008 | 02:22 AM
NumberDummy
Thanks Bill.
You didn't provide suffixes for the prefixes you listed.
There are over a dozen C5AF's alone. C5AF = 1965 Galaxie or LTD.
If the C5AF trans has 13 pan bolt holes, it's an MX Cruise-O-Matic, used with 390 engines.
C5MP is from a 1965 full sized Merc, and it's an MX Cruise-O, because that's all the big Merc's used in 1965.
MX C-O-M: 1958/67.
Neither of these trannies is an FMX, because there were no FMX's till 1969.
Julie: We have over 100 pots...just for cacti. Some were bought at Homeless Depot, Lowes, some old timers were bought at yard sales and were made by Bauer, Catalina, Gladding-McBean, etc.
Another 50 or so pots are for other plants, and another 100 or so are Pueblo Pottery (not for plants!). Some of these date back to the 90's....the 1890's.
rudifisk
Jul 2, 2015 08:48 PM
Aaron-71
62
Jul 11, 2011 04:05 PM
Midwest Dually
Jan 10, 2011 06:43 PM
ericolicious
General Automotive Discussion
Aug 25, 2008 09:10 AM
zoejazz
Apr 12, 2006 03:09 PM
