Stupid Pyrometer
Old Oct 1, 2008 | 03:48 PM
F-350PSD's Avatar
F-350PSD
Stupid Pyrometer
On my way home today my pyrometer crapped out on me. It was at around 400 degrees when it suddenly jumped to 1400 and kept bouncing between that and 1600 (max). I went to a side road and idled it, it kept bouncing. Turned it off and when I turned the key the hand swept from 0 to 1600 and then back to 0, when I trurned the key completly and started the truck it shot straight to 1600 degress and stayed there for the remander of the trip (15 min.) I checked the probe and it's still installed properly. What's the problem here? Bad guage?
-Thanks,
Chris
Old Oct 1, 2008 | 03:53 PM
secondarychaos's Avatar
secondarychaos
Sounds like you have a wire grounding/shorting.
the temp. probes operate on electrical resistance...
no resistance, it thinks it's 2000+ *F
look anywhere in the wires for metal to wire contact.
Old Oct 1, 2008 | 06:06 PM
Cuda_jim's Avatar
Cuda_jim
-Thanks,
Chris
Bad probe IMO...Autometer....give them a call. They've had trouble with them.
Good news is, They usually send a new one right away.
Old Oct 1, 2008 | 07:30 PM
Todd525's Avatar
Todd525
Could be either, but check where you run your wire thru the firewall first. DOnt go making calls until you troubleshoot.
Old Oct 2, 2008 | 10:07 AM
F-350PSD's Avatar
F-350PSD
I checked the wire in the firewall last night and secured it in a different way to make sure there could be no possible wire to metal connection. Good news is that on my way to school today (30 min.) read perfectly and didn't hop around. I'll keep you guys posted if it happens again.
Old Oct 2, 2008 | 10:15 AM
FARM69's Avatar
FARM69
Yep, if you have an autometer call them and they will send you a new one. My water temp gauge went out about a 1 1/2 after I bought it. Sure enough, they just sent me a new one.
90cclb4x4IDIzf5
Jun 14, 2016 05:07 PM
Ezalycasaid
May 20, 2015 04:22 PM
bunklash
May 16, 2015 07:46 PM
fordguy_460
15
Jul 21, 2009 05:12 PM
GreenMonster7.3
Feb 19, 2008 12:13 AM
