Problem with Pyrometer
Old Feb 18, 2008 | 06:54 PM
GreenMonster7.3's Avatar
GreenMonster7.3
Soo I ahve a 2000 7.3, DP Tuner chip, intake, exhaust. Driving down the freeway more than anything, my pyro will read about 700deg. Lately its been freaking out and reading 1200deg, then bounce to zero then all over the place rotating through the whole gague. I checked the plug under the hood and put some conductive grease on it and it didn't help. Is my Pyro sensor bad? Or is it my gague? The ground connections are all good. Any help would be sweet. Thanks.
Old Feb 18, 2008 | 07:05 PM
griff64's Avatar
griff64
Hi and welcome to FTE. Have you checked your connections on the thermo leads, if not might be gauge. I'm not real sure on this one but someone should chime in. Dave
Old Feb 18, 2008 | 07:19 PM
IDPisan's Avatar
IDPisan
What type of gauge is it? does it have an amplifier or is it a direct connect.
Old Feb 18, 2008 | 09:01 PM
AustinS's Avatar
AustinS
you can hook the thermocoupler probe to a voltmeter set on millivolts and when you start the truck it should start to rise. If it jumps all over the place too, the probe is bad. If not and all your connections are truly okay, the gauge is the issue.
Austin
Old Feb 18, 2008 | 09:26 PM
GreenMonster7.3
Its an Autometer gauge, and its a direct connect. Thanks for the insight, I'll try the connections and see if the readings are jumping all over on the Millivolt reader.
Chris
Old Feb 19, 2008 | 12:13 AM
1996pwrstrk's Avatar
1996pwrstrk
I have an Autometer pyro and I had some weird problems with it too . I ran a separate ground for it alone I have had no problems since.
