Irregular High Beam Pattern
Old Oct 1, 2008 | 05:31 AM
svt2205's Avatar
svt2205
I learned something interesting last night while changing my H13's. These lamps can be installed in multiple orientations. This can create poor beam focusing and irregular light patterns.
After installing, I always check high and low beams to make sure the lamps are good. When I hit the highs, one lamp pointed down and the other up.
So, I removed and replaced the lamps and tried different positions. In my truck, it matters which orientation the lamp has relative to the lamp assembly.
The H13 has a glass bridge inside the glass capsule. In the bridge there are 3 lead wires, 2 that are closer to one side. For orientation purposes, you need to split the head lamp into 2 segments. A top half and bottom half. Just mentally draw a horizontal line across the head lamp assembly that goes across the bulb.
If the lamp is positioned with the 2 lead wires in the top half. The high beam pattern is off. The high beam focus ends up being lower then that of the low beam. Now position with those 2 lead wires in the bottom half and the high beam focus is above that of the low beam.
Since it's so easy to do this, I tried both sides a few times. Each time the beam focus shifted.
FWIW, the H13 doesn't appear to be a lamp that is keyed to fit in only one position.
Hope this helps
Old Oct 1, 2008 | 07:44 AM
thewheelman's Avatar
thewheelman
I had a girlfriend with that problem one time, but she had surgery to correct it........oh sorry, different high beams!
I am amazed by the difference in the lights from my 01 Ranger to my 05 F-150--and it's plain on stock lights.....I feel like I'm lighting up the road for miles on high beam....same with the Mustang I just bought....
Thanks!
07EXPYEL
15
Dec 28, 2015 12:45 PM
bruno2
33
May 22, 2014 02:53 PM
Torsen Rick
Aerostar
32
Mar 1, 2011 10:15 PM
staysbroken
May 14, 2009 05:09 PM
canscrew
Electrical Systems/Wiring
Jul 12, 2005 07:59 PM
