Another Bad Motor........Possibly
Old Sep 30, 2008 | 05:42 PM
WH90's Avatar
WH90
Sup...... I was lookin for a simple work truck and came across one for 1500. its a 2001 F250 7.3 2WD Super Cab XLT Longbed. First question, the truck will not start, the air assembly looks bad mud is inside of the hose going to the turbo i didnt have my light so i couldn see it, i expect it needs an engine. Can i possibly rebuild a dusted motor and turbo.? What exactly do i need to do.
Thanks for any help!
God Bless!
Wesley
Old Sep 30, 2008 | 05:56 PM
Ponyboychris's Avatar
Ponyboychris
Mud in the intake tube??? Not a good sign. You might want to move on.
Old Sep 30, 2008 | 06:09 PM
F350-6's Avatar
F350-6
How much of the work are you wanting to do yourself? Another member recently found a pretty good deal on a short block. I know there are long blocks out there too. What kind of power are you wanting to make with it? If you plan on building it up, you'll need to make sure you don't use and of the PMR (powdered metal rods).
Old Sep 30, 2008 | 06:13 PM
Kwikkordead's Avatar
Kwikkordead
Sounds like a flood victim. That truck will need a lot more than just an engine.
Old Sep 30, 2008 | 06:15 PM
Kwikkordead
Although for $1500.00 it would be a decent purchace for getting the drivetrain out of it.
Rebuild the engine, transmission and keep the rear axle as spare for another truck.
Old Sep 30, 2008 | 06:28 PM
WH90's Avatar
WH90
Yeah i thought that to, what happened was this truck was in a fleet and when i first looked at it a corner of the housing was broke and it had unfiltered air in it. Its not a flood the inside is in good shape and its not rusted, even though im located in Hattiesburg, Ms. I wanted to rebuild the engine myself for the experience and plus i got another 2001 7.3 that alot of parts could be used for. I just didnt know if this was something i need to do.
Old Sep 30, 2008 | 07:11 PM
Ponyboychris
Grab that flashlight and go snoopin' around. if you have the ability to do more snoopin', a compression test would tell you a lot.
Old Sep 30, 2008 | 07:15 PM
Kwikkordead
^^^^What he said. ^^^^^
WH90's Avatar
WH90
Aight ill do that, i jus got a ford wds system that was given to me ill try to get some readings
Old Sep 30, 2008 | 07:39 PM
WH90's Avatar
WH90
Another thought, what components make this engine start?
Some i do know.
PCM
IDM
CPS
Electrical Connections
Correct Oil Pressure
ICP
IPR
Fuel Pressures
Anything else that needs to be checked?
Old Sep 30, 2008 | 07:42 PM
megawatt00's Avatar
megawatt00
Some i do know.
PCM
IDM
CPS
ICP
IPR
Fuel Pressures
Don't forget good batteries
Old Sep 30, 2008 | 07:46 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
God Bless!
Wesley
Man, if the body and interior are in good condition, and I mean very good I'd snap that up in a heartbeat. You can't even find SD's in the junkyard for that kind of money. If I had the money I could be in Hattiesburg in less than 8 hours, maybe 9 tops.
Old Sep 30, 2008 | 07:58 PM
F350-6's Avatar
F350-6
Don't forget the engine oil. It has to be full since the oil fires the injectors, and of course there needs to be fuel. I'd pull the air intake tube and inspect the turbo wheel for play. I'm sure there are signs of dusting. Depending on how the wheel looks, put the truck on a set of jumper cables and shoot some wd-40 in the intake and see if you can get it started that way.
Also, since there are one or two electrical components involved, don't forget to check the fuses.
Old Sep 30, 2008 | 09:14 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If you see mud in the intake and you are even asking how to rebuild a motor, chances are you probably shouldn't attempt it.
Old Sep 30, 2008 | 09:30 PM
bigsteve1969's Avatar
bigsteve1969
hey wesley i think two mississippi boys could handle it ha ha... i'm at a diesel school in tupelo so i can get a hold of everything we would need to do it!
