Tranny?
Old Sep 29, 2008 | 09:34 PM
CowboyFromHell's Avatar
CowboyFromHell
Tranny?
I have a 1977 F150 400M C-6. Its a 4x4. it does just fine at 40 or 45 MPH. When I get it up to 55 or 60 MPH and the tranny has high oil pressure it starts powering out like it ran out of fuel. When I got the truck form a cousin the tranny had problems. I think it is the torque converter but i'm not sure. Any suggestions. I replaced the fuel pump about 3 months ago and replaced filters three times since.
Old Oct 3, 2008 | 08:27 PM
paulstrans's Avatar
paulstrans
the torque converter is a fluid coupler, it reaches vortex about 1800 rpm, which makes it direct drive[to a percentage] after that. it does not recognize rpm after this. have you seen a problem with the fuel filters when you changed them.
Old Oct 4, 2008 | 02:03 PM
80F100man's Avatar
80F100man
Fuel problem mate..........tranny don't act like this, change where you buy your fuel, sounds a little 'watered down' to me
Old Oct 5, 2008 | 04:44 PM
CowboyFromHell
the filters were clean when i changed them. I always run KB gas through it
Old Oct 5, 2008 | 09:33 PM
RedFordPuller's Avatar
RedFordPuller
Start with simple stuff first check the air filter make sure its clean or $8 for a new one, spark plugs and wires, timing, vaccum advance. Check and see if it has a screen inside the carb where your fuel inlet hose barb threads in it may be varnished over and starving it at speed.
Old Oct 5, 2008 | 10:49 PM
85e150's Avatar
85e150
Silly question: Do you have two shifts? Worn linkage will result in the shifter reading D when it's in 2, which results in a doggy start and topping out at 55 or so.... Just a WAG.
Good luck if that ain't it.
bentcipher
Oct 23, 2010 10:29 PM
ripcurl94
Aug 23, 2006 07:13 AM
Petiboy
Aerostar
Aug 7, 2003 03:11 PM
FinishFirst
1997 - 2003 F150
May 30, 2002 10:22 AM
rokinrik
Bronco II
Apr 21, 2001 02:21 PM
