You can adjust timing???
Old Sep 29, 2008 | 01:28 PM
jle70's Avatar
jle70
<table width="555" border="0" cellpadding="0" cellspacing="0"><tbody><tr bgcolor="#5c6574"><td width="10" height="25">
</td> <td width="545" bgcolor="#5c6574" height="25">For your 1995 Ford Truck F250 3/4 ton P/U 4WD (7.3L Turbo Diesel):</td> </tr> <tr> <td colspan="2" height="10"></td> </tr> <tr> <td height="10"> </td> <td height="10"> Degrees </td> </tr> <tr> <td colspan="2" height="10"></td> </tr> <tr> <td height="10"> </td> <td height="10">Note:</td> </tr> <tr> <td height="10"> </td> <td height="10">
*Loosen injection pump bolts & nuts
*Rotate to align timing marks on injection pump
*Tighten injection pump bolts & nuts securely
***CAUTION***
static timing: information given provides an
initial start up condition only
dynamic timing: must be performed by a diesel
specialist to avoid extensive
engine damage
*Taken from Autozone.com
</pre> </td></tr></tbody></table>
Old Sep 29, 2008 | 01:34 PM
cchildress's Avatar
cchildress
Iv never herd of it being done that way but might be wrond I think the best way is thru programing.
Old Sep 29, 2008 | 02:12 PM
Neal 97 250's Avatar
Neal 97 250
THE HPOP cannot be rotated or moved at all. It has only one way to go on and that is not it. I would guess that is a typo.
Old Sep 29, 2008 | 02:22 PM
MADVAN's Avatar
MADVAN
IDI
Old Sep 29, 2008 | 02:27 PM
cchildress's Avatar
cchildress
Its a 95. So it its a powerstroke. unless he has done an engine swap and wanted an idi.
Neal 97 250
Wonder why it says '95. Now '94 I would understand.
Old Sep 29, 2008 | 02:34 PM
jle70's Avatar
jle70
I was just looking on Autozones tech stuff for pics and found this. I don't need to fix/adjust anything. I looked under my vehicle that's where the 1995 etc came from.
Old Sep 29, 2008 | 04:37 PM
Action4478's Avatar
Action4478
Originally Posted by MADVAN
IDI
What he said ....
Old Sep 29, 2008 | 05:06 PM
Cuda_jim's Avatar
Cuda_jim
IDI
................Ditto...............
Old Sep 29, 2008 | 05:57 PM
tjbeggs's Avatar
tjbeggs
times 3!
No diagnostic/procedure info is 100% accurate! Even the Ford and other Professional stuff!
