Trouble shifting, clutch??
Old Sep 28, 2008 | 06:48 PM
Reed97's Avatar
Reed97
Hi Fellas,
Please help a newbie. My 97 PSD 250 Ext cab 5-speed recently became difficult to shift and the clutch is starting to feel 'loose and soft' There is some oil leakage on the passenger side around the trans. and i'm not sure what is bolted on over there but it seems to have the most leakage. Putting it into 2nd and reverse is the worst, but something feels not right. Let me know your thoughts, it is my daily driver and I don't want to make anything worse by waiting. Thanks in advance for your help,
Rob
Old Sep 28, 2008 | 09:16 PM
RubberDuck's Avatar
RubberDuck
Rob, welcome to the forum.
First the shifting..... There is a clutch bushing on the pedal linkage above the throttle pedal that is prone to failing. Most people replace it with a unit from Ebay that used a heim joint. That's a very common failure for our trucks. Poke your head under the dash and check it out. Remember, the clutch rod is not directly above the clutch pedals. It's above the throttle. You'll see what I mean.
Second, the oil leak. These motors have a drain hole in the bottom of the valley where the turbo, fuel pump, and fuel bowl sit. They all drain through that hole and it travels down the front of the tranny. Most likely your oil leak is on top of the motor. Hope that helps.
Old Sep 29, 2008 | 02:03 PM
ike jensen's Avatar
ike jensen
Hi, I am having the same problem with my clutch pedal linkage. The nylon bushing only lasts about 3 months before it breaks again ($10 to replace a
5 cent part) Right now the
joint is being held together with bailing wire. The aftermarket hiem joint
sounds like the right solution but I can't find it on Ebay or otherwise. Does
anybody have a source for these parts or perhaps another solution.
My 96 powerstroke and I thank you.
Old Sep 29, 2008 | 02:23 PM
Neal 97 250's Avatar
Neal 97 250
Look here:
eBay Motors: FORD Clutch Rod End PERMANENT Repair powerstroke too. (item 260293476284 end time Oct-05-08 18:32:07 PDT)
Old Sep 29, 2008 | 03:24 PM
ike jensen's Avatar
ike jensen
Hey,
Thanks, this is exactly what I needed, good-bye bailing wire -- hello working clutch. Finally a fix for Ford's miserable and cheap engineering. The first time that plastic insert failed I almost had a wreck. Since then I always
have the truck in neutral when stopped at a light or traffic. I will install
this this weekend and stop worrying. Great Job Forum!!
Old Sep 30, 2008 | 08:24 AM
Neal 97 250
Oh yeah...Welcome to FTE.
Old Sep 30, 2008 | 09:20 PM
73cntry's Avatar
73cntry
Neal that part looks pretty sturdy and not badly priced!!!
Old Sep 30, 2008 | 09:29 PM
Reed97's Avatar
Reed97
Thanks for the help guys, I will let you know how it goes.
Old Sep 30, 2008 | 11:44 PM
884x4broncoII's Avatar
884x4broncoII
i did the e-bay bushing on my truck works awsome
artfd
22
Apr 11, 2012 02:42 PM
barryr
1983 - 2012 Ranger & B-Series
Jan 17, 2005 04:12 PM
niteowl
Jul 20, 2004 10:40 AM
GMK
Aug 15, 2003 10:47 PM
